crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Does your CAT S22 Flip become extremely hot and begins working slower or stops working? Use this troubleshooting guide to help diagnose why.
Overuse
Your device could be overheating due to using the device for extended periods of time or being in a hot environment. You can try the following.
  • Take a break
  • Leave the phone in a cool environment
Many phones will overheat when they have been used a lot in a hot environment so this could fix the problem.
Faulty Battery
The battery is aged by time or has external damage from outside sources. Causing the device to not hold a charge or not turn on. Check the battery for the following.
  • Visible damage
  • Run down battery
To replace the battery, follow this guide.
Faulty Charging Port
The charging port could stop working properly due to the following.
  • Dust build-up
  • Bent pins
  • Corroded pins
If the charging port is dusty, you can blow air into the port until the dust is removed. If there is a pin problem, you may need to replace the entire charging port by following this guide.
Damaged Motherboard
Overheating causes permanent damage to internal parts causing devices to be unresponsive or have problems with usage. Follow part of this guide until you can see the mother board to check it for the following.
  • Burned spots
  • Solder eroded
  • Pins broken
If any of these problems are present, follow the rest of the replacement guide.
Stephan Shaffer
crwdns2935283:009/25/25crwdne2935283:0
234 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-5, Harold Fall 2025 crwdns2935289:0University of North Texas, Team 2-5, Harold Fall 2025crwdne2935289:0
UNT-HAROLD-F25S2G5
crwdns2935297:096crwdne2935297:0
crwdns2942667:0crwdne2942667:0 408
