crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Out Of Bluetooth Connection Range
The Bluetooth range for Bose speakers is about 33 feet. Sometimes walls, doors, and other devices with their bluetooth on which were previously connected to your Bose speaker can distort and degrade the audio.
Other Sources Of Interference
Electronics can pick up on interference from other products in close proximity. If possible, turn off those other products in the proximity.
Disconnect your device from the speaker and reconnect.
Every phone has an EQ (equalizer) setting which allows you to adjust the sound quality of the music.
If you are using the iPhone music app:
  1. From the iPhone’s home screen, tap Settings.
  2. From the sidebar, tap Music. The screen shown below appears.
  3. Tap EQ. The screen shown below appears.
  4. Tap a preset, such as Rock. The key is to select a preset that matches the type of music you normally listen to. Keep tapping presets until you find one that gives you the best audio.
If you are using an app such as Spotify or Pandora you will have to go to the settings of that app and adjust them until you find a preset that gives you the best audio.
Faulty Speakers
If the audio sounds distorted make sure that the integrated microphone system is not damaged. It may need to be replaced.
crwdns2935291:0crwdne2935291:0
Emma Richey
crwdns2935283:003/21/22crwdne2935283:0
915 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-3, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 1-3, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S1G3
crwdns2936753:030crwdne2936753:0 57
crwdns2959996:0crwdne2959996:0 911
