crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Improper Connection
Make sure that the power cord is properly connected at both ends. Unplug both ends of the power cord then reconnect both ends firmly to the speaker and the USB power source.
Out-of-Date Software
Be sure to check for available updates for the product as outdated versions of the software can sometimes cause issues. This will fix bugs and provide the latest features and enhancements. This can be accomplished through the Bose connect app or your computer. After connecting the product to your computer, follow the update instructions on the Bose website.
Software Malfunction
You may need to reset the product to bring it back to its default factory state. Keep in mind that this will delete all saved settings. To do this:
  • Press the power button to turn on the speaker.
  • Press and hold the power button for 10 seconds. Wait until you see a blinking blue light coming from the Bluetooth button. You will then hear a voice prompt asking you to select a language.
  • Set up the Bluetooth speaker.
Faulty USB Cable
If the USB cable included with your product still does not allow it to charge after ensuring firm connection and the updates and reset do not help the issue, try connecting your product with a different USB cable.
Faulty Power Adapter
If you have replaced the USB cable and the product still does not charge, you may need to replace the AC adapter. AC adapters with a higher current rating generally charge products faster than those with a lower rating. Current ratings are typically listed on the label for the AC adapter in Amps (A) or milliamps (mA). A current rating of 1 A / 1000 mA or higher is recommended. The closer the amp rating of the AC adapter is to the maximum amp rating of the product, the more quickly the product will recharge.
Refer to the specifications indicated on the product or within its owner’s guide for details. Be sure to use a safety-agency-approved AC adapter that meets local regulatory requirements (e.g. UL, CSA, VDE, CCC).
Faulty Battery
After exhausting all other methods, you may need to replace your product’s battery. With prolonged use, lithium ion batteries deplete their function overtime. The normal charging power for a lithium ion battery is about 300-500 charging cycles. To avoid future problems, be sure to purchase a genuine replacement battery.
crwdns2935291:0crwdne2935291:0
Emma Richey
crwdns2935283:003/21/22crwdne2935283:0
915 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-3, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 1-3, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S1G3
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 164
crwdns2959996:0crwdne2959996:0 4,008
