crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Power will not turn on when running on the battery
The battery is connected, but the speak will not turn on
Battery Protection Mode Active
The SoundLink II Speaker goes into Protection Mode, if not used or charged in 2 weeks time. To remedy this, connect the speaker to an A/C outlet power source.
Battery is damaged or not charged
Make sure the battery is fully charged before removing it from the A/C power source. This will ensure the battery has an adequate charge to function.
The battery may be damaged or can no longer function. This can happen over time with general wear and tear. In this case, replace the battery. The following link is a step by step instruction for removing the battery.
Power will not turn on even when connected to a power source
The speaker is connected to the outlet, but the speaker will not turn on
Damaged Outlet
Make sure that the outlet is properly functioning, since sometimes the breaker might be out or the outlet is not installed properly. Use the outlet test button, if there is one, or connect a functioning device to the outlet to confirm the outlet is functional.
Incorrect connection to power source
Make sure the power cord is correctly inserted into the outlet and to the power port in the back of the speaker as some chances the cord will not be set properly.
If the speaker is connected to a surge protector, make sure the surge protector is turned on and properly connected to the outlet. If it still does not work, plug the power cord directly into the outlet.
Damaged or broken charger or cord
If the speaker is still not working properly, the power cord may be damaged due to wear and tear. If this is the case, you will need to replace the power cord.
Speaker indicates a connection, but there is no audio
Speaker and device show a Bluetooth connection, but there is no audio playing
Volume Low Or Muted
If there is no audio playing through the speaker, the volume on the speaker or device may be too low due to manual or automatic volume change. Check the speaker's volume setting and adjust accordingly. If there is still no audio, check to see if the device's audio is low or muted.
Device Not Connected Properly
There may not be any audio playing because the device isn't paired correctly. Check to see if the speaker and the device are correctly paired.
Bluetooth Has Trouble Connecting
The speaker and the device will not pair correctly
Software needs an update and/or reset
First, check to see if the speaker is running the latest software version. Go to the Bose Software Update Center to check if your speaker is up to date in software.
Second, if the speaker is up to date, preform a reset on the speaker and the device.
Third, make sure you are connecting to the right device in the Bluetooth menu.
Bluetooth Is Off
Check to see that the Bluetooth setting are turned on and searching for a device to pair with.
Device is out of range
The speaker's Bluetooth has a limited range. When attempting to pair the devices, make sure that the device is around 6 ft. to the speaker.
Too Many Devices Paired with the Audio Device
If there are many devices paired with the audio device, try to remove a couple paired devices. The audio device may be attempting to pair with a different device.
When attempting to pair the speaker and the audio device, make sure to select the speaker in the audio device's Bluetooth menu.
Kevin Bailey
crwdns2935283:009/24/15crwdne2935283:0
528 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 22-4, Rauch Fall 2015 crwdns2935289:0Texas Tech, Team 22-4, Rauch Fall 2015crwdne2935289:0
TTU-RAUCH-F15S22G4
crwdns2944067:032crwdne2944067:0
REALLY helpful thanks for all the advice!
gregoriozanivan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Volume Up and Down Not Working. What should I do?
Carlo Reyes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my bose sound link 2 won’t turn on at all and none of these issues apply to me. is there a reset like with the sound link color?
royce - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
same with me, when plugged, it only indicate with 3 blinking lights and then its goes off
Mike Olabamiji - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my bose does play with bluetooth, after a wile it cuts out then back in staggered repeatedly. like mute comes on on its own. batteries charged , the bluetooth range well with in range. it can be ok for a will then begins to cut in and out. can this problem be repaired ? lou 02/25/20
wanted.needed - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 227
crwdns2959996:0crwdne2959996:0 62,996
