crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Cannot connect to network
System and app need reboot
Close the SoundTouch controller app, disconnect all cables, and restart the SoundTouch and app.
App is not downloaded
Verify the SoundTouch controller app is downloaded on your computer or mobile device. Go to http://www.Bose.com/soundtouch_app to download the computer app. For your mobile device, you may download the app from that device's app store.
Not connected to WiFi
Ensure the SoundTouch is connected to the same WiFi network as your computer or mobile device. Verify the WiFi path is clear by stopping other audio or video streaming apps.
Radio play is inconsistent or doesn’t play at all
Restart all devices and applications. Press and hold the AUX button for 15 seconds to do a system restart.
Outside interference
Move the system away from other devices (microwaves, wireless devices. etc.) that may interfere with the signal.
Cannot hear an Airplay stream
Connect the SoundTouch and AirPlay device to the same WiFi network, then select the SoundTouch in the system’s AirPlay menu.
AirPlay is not on
Verify that AirPlay is on; turn up the volume on the SoundTouch to check.
Move AirPlay device away from possible interference (such as microwaves, cordless phones, and other wireless devices) and closer to the wireless router or access point. (Proximity of the AirPlay device to the SoundTouch is not important, but, the proximity of the Airplay device and the wireless router or access point is.)
Mobile device/computer and router need reboot
If the previous steps do not work, restart your mobile device, or computer, and router.
System does not turn on when operating on battery power
Battery is in Protection Mode
Check to see if the battery is in Protection Mode; if it is, then turn off Protection Mode.
Battery is not charged
Check to see if the batter is not charged. If it is not, connect the SoundTouch to a power source to charge the battery (audio cannot play unless the battery is charged to at least 10 percent).
Defective battery
If the system still does not power on, contact Bose customer support.
Battery too hot or cold message appears on the display screen
SoundTouch is too hot or too cold
Move the SoundTouch to a place with a cooler or warmer temperature and wait for the battery to cool down or warm up.
Chelsea Martin
crwdns2935283:002/20/17crwdne2935283:0
706 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G3, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G3, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G3
crwdns2935297:0108crwdne2935297:0
crwdns2944067:05crwdne2944067:0
hi, i ve just updated my bose soundtouch portable on my mobile apps, but after that its doesnot play now?and its not loading aswell. there is a rectangle bar on the screen but doesnt loading/?any heplwill be appreciated,
regards,
cy
Cyril Albania - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Bose SoundTouch has stopped playing. No sound. It connects to WiFi. Connects to AirPlay. You can even see track information/ station information on the display, but no sound. Shut it off for few days, and disconnect the power cable, start it again, it starts playing. I wonder if it’s one of the recent software update that has wrecked it.
Anshuman Singh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have deleted and reinstalled app and SoundTouch but still hav same stations and favorites saved on app. It can’t connect to some Tunein stations.
Aivo loigom - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Updated Bose SoundTouch 20. Did not work after. Factory Reset based on guide but not 2 and -Volume states “Action Unavailable” what’s next?
Alvin Ygona - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Soundtouch portable -> changing battery to a new one -> battery was 50% loaded -> portable starts and run normal -> but the battery will not charge?! 220V adapter deliver 20V and is working fine.
Does anybody have a solution to get the portable charging the battery? I´m able to open battery and charging the battery external but no chance to get them loaded by portable.
W Bachmann - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 101
crwdns2959996:0crwdne2959996:0 7,623
