crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Do your Bose QuietComfort 15 headphones power on but do not produce any sound? Use this troubleshooting guide to help diagnose why.
Faulty Cable Connection
The cable not being fully seated into the earcup can prevent audio from reaching the Bose QuietComfort 15.
Ensure that the cable makes an audible clicking noise when plugged into your Bose QuietComfort 15 and then test the sound. If there is still no audio, then the problem may be in the audio cable.
Faulty Audio Cable
A damaged cable can prevent audio from reaching the Bose QuietComfort 15.
Inspect the cable for fraying, bent connectors, or exposed wiring. Gently move the cable while audio is playing to check for intermittent sound. If damage is present or sound cuts in and out, replace the cable with a known-working QuietComfort 15-compatible cable.'
Faulty Battery
The battery not being plugged in correctly, damaged, or dead can prevent the audio from reaching the Bose QuietComfort 15.
Inspect the battery to ensure it is in the correct position and is not damaged in any way. If no damage can be seen on the battery, see our replacement guide on how to replace the battery.
Brayden Webb
crwdns2935283:002/04/26crwdne2935283:0
512 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 41-5, Johansen Spring 2026 crwdns2935289:0Texas Tech, Team 41-5, Johansen Spring 2026crwdne2935289:0
TTU-JOHANSEN-S26S41G5
crwdns2935297:048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 301
