crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Bose AE2w headphones produce distorted audio (e.g., static, imbalance) during playback, follow this page for solutions.
Low Battery
Low power can affect audio quality.
  • Charge the AE2w fully using the original cable and power adapter
  • Test audio while charging to see if distortion persists
Bluetooth Interference
Wireless signals or other nearby electronics can cause audio distortion.
  • Move away from Wi-Fi routers, microwaves, or other Bluetooth devices
  • Ensure you are at least within 30 feet of the audio source
  • Too many Bluetooth connections to the same device could cause audio issues
  • If all else fails, try to reinstall Bluetooth drivers.
Dirty or Damaged Audio Jack
Physical debris or damage to the jack can disrupt the connection.
  • Ensure the audio jack is clean and free of debris
  • Ensure there is no damage to the audio jack
  • A dirty audio jack can be cleaned with rubbing alcohol and cotton swabs
Worn or Loose Earpiece Speakers
Internal speaker damage could cause distortion.
  • Gently press on each earpiece while also playing audio—if the sound improves, the speaker may need reseating.
  • Replace the earpiece speakers if the distortion persists.
Software Glitch
Outdated firmware could cause audio problems.
  • Make sure that your device—both the mobile device and the headphones — is up to date on all software updates using the Bose Connect App.
  • Check the settings of your primary music app, as issues may arise from updates or outdated versions. Ensure the app is up to date to prevent potential problems.
  • Go to the Bose website, navigate to the support page, and select your device. Check the latest available driver version listed there and compare it to the version currently installed on your device.
Faulty Bluetooth Module
A malfunctioning module could disrupt wireless audio.
  • Reset the AE2w (hold the power button for 10+ seconds).
  • If the issues persist, replace the Bluetooth module.
If necessary, or if any of the suggestions do not work, contact Bose Customer Service and ask what to do.
Ben Ponte
crwdns2935283:003/24/25crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-4, Biswokarma Spring 2025 crwdns2935289:0UMass Dartmouth, Team 5-4, Biswokarma Spring 2025crwdne2935289:0
UMASSD-BISWOKARMA-S25S5G4
crwdns2942667:0crwdne2942667:0 259
