The blender is plugged in and turned on and the blades aren't spinning. Here are the most likely issues.
First, verify that your blender is plugged in and using an outlet that currently works for another appliance. If your outlet isn't working for any device, try reseting the breaker.
Blender Overloaded
Solids like ice and frozen fruit might have stopped the blades from turning. Turn off the blender and unplug it. Open the blender and carefully remove any solids from under the blades to avoid injury. Then close the blender, plug it back in, and turn it on.
Blade Not Seated
The blade often sits on a shaft where it spins. After cleaning the blender, verify the blades are sitting flush and can spin freely. This might sound like the motor working, and the blades shaking back and forth.
Blade Assembly Failure
The blade assembly is made of two parts typically: blades and bearings. By blending hard objects, blades will dull and cause the motor to work harder and overheat. Blades last an average of 6 months with moderately heavy use. Sharpen or replace the blades if they are dull.
The bearing inside the assembly may also fail from overuse and misuse. Some blenders, like the Vitamix, are intended for running at their max speed in order for the cooling fans to properly work. In some cases, the bearing seal may melt or otherwise disintegrate. Water will then infiltrate the bearings during cleaning and wash away grease and cause rust to form. Replace the bearings or entire blade assembly if the blade won't spin.
Power Button is Stuck or Unresponsive
If the power cord is plugged and has not short-circuited, the power button might be stuck or unresponsive. It's possible that there is grime or other buildup in the switch preventing operation. Try switching on and off to cycle the switch.
Drive Gear Stripped
Where the motor and blade assembly connect is a drive gear. On blenders with plastic gears the teeth may wear down more quickly.
  • Inspect that the gears mesh and aren't stripped.
  • Use a large flat head screwdriver to remove and the gear if it's missing teeth.
On some blenders the drive gear and motor shaft may be threaded and have stripped threads. If the gear wobbles it's a good sign that it's stripped.
  • Try wedging a screwdriver under the gear and turning the motor by hand to tighten the connection.
If it's too stripped, the manufacturer will likely recommend replacing the entire base. Try this fix.
  • Glue together the shaft and rubber gear with a steel epoxy. This connection will be snug after curing.
Failing Activators
Liquids find their way onto and into the motor base. The interface between the cup and the motor base is prone for fluid and grime accumulation. The activators are the three white switches that initiate the blending to begin by locking in the cup and should move up and down with a spring action.. You can test the activators by pushing the three switches down with a flathead screwdriver. If the switches will not move, add a few drops of warm water or vinegar into the activator slots and wait a few minutes before trying again.
Motor Burnout
A blender that is working too hard processing frozen foods, hard nuts, thick butters, flax seeds, cell phones, glow sticks, etc. will be working harder and may eventually burnout or stall.
Your blender may be equipped with a thermal breaker that shuts down the motor if it starts overheating, so while there's little risk of fire, the blender still might start smoking. If the blender is running for more than a minute on a low power speed, it's likely the motor overheating. Let the blender cool down.
Blender Lid Stuck
Blender Smells Like Burning
Blender Smoking
Blender Leaking From Bottom
Blender Not Working
Additional Resources
Oyster Worn Drive Shaft Replacement
crwdns2935291:0crwdne2935291:0
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,990 crwdns2915208:0crwdne2915208:0
crwdns2935297:088crwdne2935297:0
Global Fixers crwdns2935289:0Global Fixerscrwdne2935289:0
Community
crwdns2931471:072crwdne2931471:0
crwdns2935297:03,060crwdne2935297:0
全く、電源が入らない。
購入先は、スーパーカマシンです。
とまと - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 126
crwdns2936753:030crwdne2936753:0 504
crwdns2959996:0crwdne2959996:0 19,190
