crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Identified by model number BH350. When you turn it on and it does not heat up but there is power, follow these steps to get your device to heat up.
Heating Element is Broken
- Make sure that the curler is plugged into an outlet that works. Try a different socket to rule out external power problems.
- If your curler has a power or heating indicator light, confirm whether it turns on.
- Try giving the curler a few minutes to heat up. If it remains completely cool, the heating element may have failed.
- Look for burn marks, melting, or odd smells—signs the heating element may be damaged.
Heater Wiring is Faulty
- With caution move the cord and handle while the device is on. If the heater intermittently turns on/off, loose or damaged wiring is likely.
- look for frayed, bent, or exposed wires along the power cord which can interrupt power to the heating unit.
- A loose or wobbly plug may prevent proper electricity flow.
- Faulty wiring can pose a fire or shock hazard. Unplug immediately if you suspect wiring issues.
- Heater wiring issues often require internal repair or full product replacement. Reach out to the brand’s customer service for next steps.
