crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Microsoft Band 2 Troubleshooting
Band 2 Fails to Charge
When charger is connected, battery does not charge
Disconnect the charging cable, make sure it is free of dust and debris and then reconnect the cable, ensuring that it is fully inserted into charging port. Make sure the gold connectors on the charger match up with the gold connectors on the device clasp.
Band 2 Won’t Turn On
When trying to hold down the button to turn the device on, the screen remains black. The device is unable to be used.
Attempt to charge the device by plugging the USB port into a computer or wall charger and attach the magnetic charging connector to the charging port on the clasp of your band. Make sure that the gold connectors on the charging cable match up with the gold connectors on the device clasp.
Screen is Black or Difficult to See
Screen is difficult to see or not displaying anything.
Move the watch into a low light setting and check to see if the screen is displaying anything at all. If screen is completely black, move on to Replacing the Screen on Microsoft Band 2.
From the main menu, press the gear wheel to enter settings, scroll right and press the gear wheel again to go into advanced settings. From here, try selecting a higher brightness setting. If this does not solve the problem, move on to Replacing the Screen on Microsoft Band 2.
Sensor is not Working
Sensor won’t track changes in exercise tracking (speed, distance, elevation, and personal bests), calorie burning, and sleep quality.
Ensure sensor nodes are clean and making contact with skin when watch is worn.
Notifications Don’t Show Up
Notifications do not appear on Band 2.
Make sure “Do Not Disturb” is turned off. Attempt to restart the band. Ensure your band is properly connected to your phone.
Cannot use voice commands
Band 2 is Not Responding to Voice Commands.
Restart device.
Make sure the microphone opening is clear of debris.
Make sure the action button is functional and that you press it for a full two seconds in order for Cortana to pop up.
Chris Syracuse
crwdns2935283:002/20/17crwdne2935283:0
639 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G5, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G5, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G5
crwdns2935297:048crwdne2935297:0
One of the post on the charger has retreated and not able to make contact to charge
Sheila Ingersoll - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 2,306
