crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Sometimes the basket release button gets too loose sometimes it gets stuck
Basket release button not working
Too much grease
The grease and food crumbs could prevent the button to be pressed down all the way. To remove the grease and food crumbs, unplug and cool down the fryer then to clean around button, follow this guide.
The release hook jammed
When pressing the release button, the hook no longer detaches from the drawer. To fix this, replace the handle by following this guide.
Clear lock is too loose or gets stuck
The clear basket lock is moving without being pushed forward, Thus the release button could be accidentally pushed. To fix it, replace the clear lock by following this guide. If the clear lock is stuck, clean the slots the clear lock sits in and the lock by following this guide.
The drawer keeps popping out
The drawer release button gets stuck or loose
The crumbs get into the release button
To remove the crumbs, unplug and make sure the fryer is cooled down . To clean, pull out the drawer and follow this guide.
Heating plate slots have dents
The heating plate slots that hold the drawer can have dents or have crumbs, which can prevent the drawer to go all the way into the fryer. To clean, unplug and make sure the fryer is cooled down. To clean, pull out the drawer and follow this guide. For the damaged parts of the slot, use the repair guide here.
The spring for the draw stopper is not popping up enough or stuck
The metal stoppers to prevent the drawers to pop out during cooking could be stuck or not functional because the spring is too old or lost its elasticity. To replace the spring, unplug and make sure the fryer is cooled down then follow this repair guide.
Fan is making a loud noise
Fan is making loud noises while cooking the food
Too much oils and food crumbs cause the fan to have spin loudly
To reach the fan, unplug and make sure the fryer is cooled down. You need to take the coil off by removing the screws as directed in this guide. Then clean the fan by following this guide.
The fan could be faulty
To replace the fan, make sure the device is unplugged and cooled down. Then unscrew the heating coil and remove the fan by following this guide.
Temperature control and timer knob fails to function at the temperature/time it states
The fryer does not set the temperature or the timer to the right setting
Grease and food crumbs accumulated under the knob
When adjusting the temperature or timer knob, the fryer does not respond to the change as well or not at all. to fix, unplug the device and wait for it to cool down. to clean knob, follow this guide.
Broken wire within the device
Wiring could be fixed or replaced by following this guide.
Kazuki Mizuishi
crwdns2935283:010/22/18crwdne2935283:0
323 crwdns2915208:0crwdne2915208:0
UC Davis, Team S7-G6, Lore Fall 2018 crwdns2935289:0UC Davis, Team S7-G6, Lore Fall 2018crwdne2935289:0
UCD-LORE-F18S7G6
crwdns2944067:07crwdne2944067:0
Where can I get a replacement basket and handle for this bella model 14538. Screw lost its grip
Teresa Perez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Tengo 6 meses preguntando donde puedo encontrar la bandeja con el asa, puño, mago, manija o como se pueda llamar esa parte de la olla, y solo es logrado perder mi tiempo, por eso es que cuando ud decida comprar algo trate de que los fafricantes tengan un poquito de consideracion con el consumidor y fabriquen los respuestos. La ollas bella son desechable.
I have been asking for 6 months where I can find the tray with the handle, fist, handle, handle or whatever that part of the pot can be called, and it is only a waste of my time, that is why when you decide to buy something try to get the manufacturers have a little consideration with the consumer and manufacture the parts. Bella pots are disposable.
Manuel Read - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Todas las ollas de la marca Bella creo que son desechable, porque no tienen respuestos, por consiguiente nadie debe comprarlas.
Las ollas reidoras marca Bella se dañan a los 5 o 6 meses y tienen que desaserce de ellas porque son desechable no tienen repuestos.
My basket fell on the tile floor, now it won’t stay closed. Any idea which part I need to replace?
Liz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 2,882
