crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Tablet Won’t Power On
The laptop won’t turn on when pressing the power button.
Battery is Drained
Check to see if the charging port is clean and free of debris. Plug the device into the USB charger and plug the charger into the wall. If the LED light is orange, the device is charging. Leave the device to charge until the LED light displays white. Then the device is fully charged.
Faulty Power Adapter
Plug the USB charger into the device. If there is power to the outlet and the device is plugged into the charger and the charger is plugged into the wall, but no light is displayed on the device, the power adapter may be faulty. Consider purchasing a new adapter.
Faulty Battery
If the tablet will only power on with the USB charger plugged in, the battery is faulty. Replace the battery using this guide.
Tablet Becomes Unresponsive
Tablet freezes and won’t respond.
Device Needs a Hard Reset
Press and hold the power button for 5 seconds to hard reset device. Wait for about 30 seconds before restarting the device. Another method for resetting includes inserting a paperclip into the reset hole on the device. The location of the reset hole can be found in your user guide.
Device Needs a Factory Reset
Warning: This reset will erase all of your information! Try a factory reset by first connecting a USB keyboard and the power adapter. Then, power on the tablet while pressing the shift key on the keyboard. Choose "Troubleshoot", then "Reset your PC". Finally select the “Fully Clean the Driver” option for a factory reset.
Device Won’t Connect to WiFi
Device won’t connect to WiFi or the internet.
WiFi is Not Enabled
Check to make sure that WiFi is enabled under the settings tab.
Press and hold the power button for 5 seconds to hard reset the device. Wait for about 30 seconds before restarting the device. Another method for resetting includes inserting a paperclip into the reset hole on the device. The location of the reset hole can be found in your user guide.
WiFi Settings Need to Be Reset
Go into settings and under the WiFi section, choose the option that says "reset network settings". After the settings are reset, power down and restart the device then connect to the network again.
Router and/or Modem Issues
If you still cannot connect to WiFi, you may be experiencing problems with your router and/or modem. First turn off the device, then turn off your router and/or modem. After 30 seconds, turn your router and/or modem back on, and attempt to connect through your device. If you still cannot connect, there may be issues with your service provider.
Device Will Not Wake from Sleep Mode
The device’s screen goes black during sleep mode and will not wake with the power button.
Press and hold the power button for 5 seconds to hard reset the device. Wait for about 30 seconds before restarting device. Another method for resetting includes inserting a paperclip into the reset hole on the device. The location of the reset hole can be found in your user guide.
Screen Has Lines Going Through It
The device has lines displayed vertically or horizontally across the screen.
Use a micro HDMI cord to plug the device into an external display. If the lines appear on the external display as well, it is a software issue. If the lines do not appear on the external display, see the faulty screen section below. Hold down the power button for 5 seconds to completely power off the device. Wait for 30 seconds before powering the device back on. Another method for resetting includes inserting a paperclip into the reset hole on the device. This can be found in your user guide.
Warning: This reset will erase all of your information! If a hard reset does not work, press the windows start button. Then, swipe all the way to the right and tap on the magnifying glass in order to search. Click on setting, type factory, and then select “Remove everything and reinstall Windows” from the list option on the left. Click next to begin. The factory reset usually takes about 30 minutes to restore.
Faulty Screen
The screen could be faulty and may need to be replaced. Use the replacement guide to replace the screen here.
Jake Hines
crwdns2935283:010/06/16crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 2-4, Sullivan Fall 2016 crwdns2935289:0USF Tampa, Team 2-4, Sullivan Fall 2016crwdne2935289:0
USFT-SULLIVAN-F16S2G4
When I charge my vivotab k0x for 8 to 16 hours the led stays solid orange. When I press the power button for a couple of seconds the led blinks 3 times, whether charging or not. Inserting a paperclip into the reset switch hole does nothing, holding the power button and the volume down button does nothing. What do 3 blinks indicate?
mscir - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 10,396
