crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The Nexus Player will not Boot
The Player will not load up or will bring up an error message.
A Hard Drive Failure
The hard drive may have malfunctioned and may need to be replaced.
The Remote Will Not Connect
You are unable to communicate with the nexus player with the remote.
Out of The Remote's Range
The remote may be out of the range of connectivity. Make sure you are close enough to the device.
The Remote May be Dead or Have Low Battery
Make sure the remote has batteries with charge.
The Remote is Not Synced to the Device
The remote may not be synced to the device. To do this press the back button and the home button on the same time for five seconds.
The Nexus Player Will Not Power On
Nothing happens when the power button is pressed.
A Faulty Power Cord
Check to see if the cord is fully plugged in. If it is fully plugged in and the Nexus Player is still not powering on, then the cord is faulty. Consider buying a replacement cord.
There is No Audio and/or Video
The Nexus Player is on but nothing is showing on the screen and/or no sound is heard.
A Faulty HDMI Cord
Check to make sure the the HDMI cord is fully connected to the device. If the cord is fully connected and there is still no sound and/or video, then the cord itself may be faulty. Try using a replacement cord.
An App Crashes or is Not Responding
Apps consistently crash or player is unresponsive.
The Device keeps Crashing and Will not Respond
First reboot the device, and after it has rebooted check for system and app updates. If still unresponsive or crashing occurs then force stop, clear app cache and data or uninstall and reinstall the app.
Unable to Connect or Not Responding to Controls
The device is not able to connect through WiFi or Bluetooth.
Unable to connect to the WiFi
If you are unable to connect to WiFi check the network settings and make sure they are all correct. If they are all correct and it still will not connect try resetting the network settings.
Unable to Connect to Bluetooth
If your device is not connecting through Bluetooth, check to make sure Bluetooth is enabled. If it is still not connecting try going through the general troubleshooting steps.
Eric Smith
crwdns2935283:002/15/17crwdne2935283:0
113 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-1, Passmore Spring 2017 crwdns2935289:0USF Tampa, Team 5-1, Passmore Spring 2017crwdne2935289:0
USFT-PASSMORE-S17S5G1
so where do we get a replacement Hard Drive?
Gerard Roy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 42
crwdns2959996:0crwdne2959996:0 2,865
