crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Tablet Won't Power ON
Tablet doesn't show any signs of responding or powering on.
The Battery Is Depleted
Plug in the power cable that came with the tablet. If the tablet responds, it means the battery was depleted and needed a charge.
The Cord Is Broken
If plugging the charging cable in did nothing, try another cable of the same type, voltage, and amperage. If the tablet responds the charging cable needs to be replaced.
Power Button Is Faulty
The power button may have broken due to use. To replace this part follow This Guide.
The Battery Is Dead
If the cord is not the issue, the battery may be dead and need to be replace. To replace the battery use This Guide.
Touchscreen Is Unresponsive/Erratic
Touchscreen will NOT respond to most touches, or will indicate a touch was made when none occurred.
The Screen Is Dirty
Clean the screen with a light cloth, microfiber if you have it. This will remove any oils or other obstructions on the screen.
Touch Diffuser is Faulty
If the problem persists after cleaning, the touch diffuser may be faulty.
Screen Does Not Show Up
There is no video showing on the tablet, or the video is distorted in some manner.
The Screen Is Dirty
LCD Is Faulty
If the problems persist, the LCD Screen may be faulty.
SD Card Won’t Read
An SD Card is inserted into slot, but the card isn't detected and/or read properly.
The SD Is Faulty
The problem may lie in the SD Card. Try to have another card read via the tablet or try reading the card through another device to ensure that the tablet is not at fault.
The SD Card Slot Is Faulty
If changing the card did not solve the problem, the reading slot itself may be the problem. To replace this part follow This Guide.
The Front/Rear Camera Doesn’t Work
When attempting to take photos the camera will not capture the picture, or no picture feed appears when using the camera.
The Camera is Obscured
Try cleaning the camera lens to be sure that there is no obstruction hindering photo capture.
The Camera is Damaged
The camera is non-functional and therefore needs to be replaced. To do this follow Front Camera Guide/Rear Camera Guide.
Sound is too Low or Does not Work
The volume is considerably lower or does not play back whatsoever.
Volume Settings are Low
Check settings to confirm that volume is at preferred setting.
Turn Off Power Saver Mode
Sometimes volume can be considerably softer in power saver mode.
Faulty Headphone Jack
First, check your headphone set to be sure that is not the issue.
Faulty or distorted Speakers
Test speakers on different applications (i.e. music player, phone call) and if the problem is consistent, reset the phone. If the speakers are indeed faulty, you may need to replace them using This Guide.
Microphone Doesn’t Pick Up Sound
The Microphone does not pick up sound at all, or sound captured is perceived as lower than intended.
Check playback volume
Make sure that the playback volume is at an adequate level to be sure the audio is playing correctly.
The Speakers Are Not Working
Try playing the audio file on another device. If the file plays and audio plays properly this may mean the speakers on your MeMO Pad may be faulty.
The Microphone Is Faulty
The Microphone itself may be faulty and need replacing.
Richard Kennedy
crwdns2935283:010/13/16crwdne2935283:0
12 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 5-6, Lacy Fall 2016 crwdns2935289:0USF Tampa, Team 5-6, Lacy Fall 2016crwdne2935289:0
USFT-LACY-F16S5G6
crwdns2935297:036crwdne2935297:0
My screen is cracked and all though I get power I cannot do anything it’s unresponsive to touch
Deanaling - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 44
crwdns2959996:0crwdne2959996:0 1,432
