crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Chromebook Flip C214MA has issues charging or will not turn on, follow this guide to resolve the issue.
Debris in Charging Port
The charging port may be partially obstructed, preventing it from making a connection. Inspect the charging port for any debris. To clean it use a plastic dental pick, wooden toothpick or compressed air. Avoid using metal tools to not damage the charging port.
Faulty Charging Cord
Check multiple outlets to ensure the issue is not from the power source. Leave your Chromebook Flip C214MA charging for 30 minutes to one hour before attempting to turn on again. If your Chromebook Flip C214MA still is not charging, check for any damages, fraying, or wear and tear on the cable. A new charger may be needed if damage is found.
Hard Reset
To perform a hard reset of your Chromebook Flip C214MA, leave the charger plugged in and press and hold the refresh button and then click the power button.
Faulty Battery
If your Chromebook Flip C214MA still does not turn on then there is likely an issue with the battery.
To replace your battery, please follow our guide: ASUS Chromebook Flip C214MA Battery Replacement
Cameron Choiniere
crwdns2935283:002/04/26crwdne2935283:0
411 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 41-2, Johansen Spring 2026 crwdns2935289:0Texas Tech, Team 41-2, Johansen Spring 2026crwdne2935289:0
TTU-JOHANSEN-S26S41G2
crwdns2935297:070crwdne2935297:0
crwdns2942667:0crwdne2942667:0 123
