crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Apple TV Won’t Turn On
The Apple TV device won’t power on.
Power Cord Not Connected
Be sure the power cord is plugged into a power source and that the Apple TV’s status light is on.
HDMI Cable Not Connected
Check to see if the HDMI cable is securely plugged into the HDMI port on the back of the Apple TV as well as into the HDMI port on the television. If the television has multiple HDMI ports, try plugging the cable into each of them to see which one produces the desired results.
Television/Receiver Not Powered On
Check to see that the television or receiver is plugged into a power source and turned on.
Incorrect Display Mode
If the device turns on but the screen only displays a black screen, press and hold the Menu and Up buttons on the remote for 5 seconds. The device will now change resolution settings every 20 seconds. When the television displays a resolution you are happy with, select OK to set the resolution settings.
Apple TV Unresponsive to Remote Commands
The remote is not responding and you lost control over your Apple TV.
Connection Between Remote and Apple TV Blocked
Be sure there is nothing obstructing the path between the Apple TV and remote. Relocate any possible obstructions.
Connection Needs Rebooting
If there is nothing obstructing the path, you may need to disconnect and reconnect the remote to the Apple TV. To do this, press the Left and Menu keys for 6 seconds. Look for an icon that looks like two unconnected chain links above the remote symbol on on the Apple TV device. To reestablish the connection, hold down the Menu and Right keys on the remote for 6 seconds. Check the AppleTV to see if the icon has switched to an image of two connected chain links. Your Apple Device and Remote are now reconnected.
Connection to Power Source Needs Restarting
If all else fails, you can always try to unplug the AppleTV from the power source and plug it back in after waiting several seconds.
Dead battery
Replace the battery in your Apple Remote.
Blank Black Screen
The screen goes totally black, you can’t play any media on it and it’s not responding.
Apple TV Needs to be Restarted/Restored
If the light flashes for longer than three minutes, it is time to restore the Apple TV. To do this, be sure to have iTunes open on your computer. Unplug the HDMI cable and power cord from the Apple TV and, using a USB cable, plug the Apple TV into your computer. If iTunes doesn't automatically open the Apple TV summary page, click on the Apple TV icon in the upper left corner. Choose Restore Apple TV from the provided options and let the restoration process proceed to completion. When it is finished, unplug the Apple TV from the computer and reconnect the HDMI cable and power cord to the Apple TV.
Incorrect HDMI Settings
If the light on the Apple TV remains steady and doesn't flash, unplug both ends of the HDMI cable. After waiting a few seconds, plug the cable back into the ports. Turn off the TV and, if you use one, the receiver, and unplug the TV from the power source, plugging it back in after a few seconds. Turn the TV and receiver back on and open the TV menu, selecting the HDMI input. Connect the Apple TV directly to the TV, without the use of a receiver or HDMI cord to test if the problem is in the switch or receiver. If this hasn't fixed the problem, try a different HDMI cable.
No Lights Displaying on Device
No lights on the Apple TV are lighting up.
If the Apple TV isn't displaying any lights, unplug the Apple TV from the power source. Wait for about a minute (60 seconds) and plug it back in. If this doesn't work, try a different power outlet. If this doesn't work, plug the Apple TV into the computer using a USB cord and use iTunes to restore the Apple TV.
Lights Blinking Continuously, Device Unresponsive
A light on the Apple TV box blinks continuously and doesn't respond to remote commands.
Device Needs Restarting via Menu Options
The blinking light means the Apple TV needs to be restarted. This can be done by opening the Settings menu, selecting General and finally choosing Restart from the listed options.
Device Needs Restarting via Remote
To restart the Apple TV using the remote, press and hold the Menu and Down buttons. Release the buttons when the light goes out, then comes on again.
Connection to Power Source needs Restart
Unplug the Apple TV from the power source. After waiting 30 seconds, plug the device back into the power source.
Device Needs to be Restored to Factory Settings
To restore the Apple TV to its factory settings, open up the Settings Menu, select General and choose Reset from the options listed.
Device Needs to be Updated
Using a micro USB cable, connect the Apple TV to your computer and wait for iTunes to open. Once iTunes has opened, it will provide the option to install/reinstall the most recent update.
AirPlay Mirroring Issue with Apple TV
If you can't mirror or stream content from your iOS device to your Apple TV or other AirPlay enabled device.
Devices Need to be Updated
Using a USB cable, plug your Apple TV into the computer and use iTunes to download updates.
Your Devices Are Not Compatible
Make sure your device is AirPlay compatible. Airplay content can only be played to an Apple TV or AirPlay enabled receiver or speaker. AirPlay content cannot be played via an iOS device to another iOS device or Mac.
Areej Bashawiri
crwdns2935283:009/28/17crwdne2935283:0
246 crwdns2915208:0crwdne2915208:0
University of Maine, Team S1-G2, Diaz Fall 2017 crwdns2935289:0University of Maine, Team S1-G2, Diaz Fall 2017crwdne2935289:0
UMAINE-DIAZ-F17S1G2
crwdns2935297:048crwdne2935297:0
crwdns2944067:05crwdne2944067:0
Apple tv2 remote ‘up’ press does not activate movement on screen? Impossible to move up to select a letter above where last letter lower was selected..
gerhardbeukes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Device says it needs to be activated
George Cryor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I Restarted/Restored my Apple TV and it started working. Thanks for the solution. Great help
Harshini Dasari - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
POS Apple TV never worked consistently
Bill Strang - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My device is showing video but there is not sound. The television set does play sound on normal TV What can be wrong? No Audio
Edwin Flynn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 128
crwdns2959996:0crwdne2959996:0 56,045
