crwdns2862674:0crwdne2862674:0
This wiki page is a stub. Help us improve this page by adding information to it!
crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Anker Soundcore Select 2 A3125 speaker isn't charging as expected, this troubleshooting guide may provide some solutions.
Faulty Charging Cable
Visually inspect the charging cable for any physical damage. Look for damage to the connector, or a crimped/frayed part of the cable. If there are no signs of damage, plug the cable into a different device. If it still does not charge, the charging cable is broken and must be replaced.
Faulty Battery
If the speaker works while plugged in, the charging port and charging cable do not need replacement, and the speaker dies shortly after removing it from the charger; the battery must be replaced. Follow this guide to replace the battery in your speaker.
Faulty Charging Port
For the Select 2, an LED indicator shows that the device is charging. If this light isn’t on, the charging port likely needs to be replaced. Follow this guide to replace the charging port.
Paul Peters
crwdns2935283:003/11/26crwdne2935283:0
465 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team 7-7, Dieterle Spring 2026 crwdns2935289:0Purdue University Northwest, Team 7-7, Dieterle Spring 2026crwdne2935289:0
PNW-DIETERLE-S26S7G7
crwdns2935297:048crwdne2935297:0
crwdns2942667:0crwdne2942667:0 112
