crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Anker Soundcore Life Q20 headphones are not charging fully or properly, follow this guide.
Headphones Need Reset
The Anker Soundcore Life Q20 headphones may need to be reset if they are not charging correctly.
  • Delete the pairing history from your Bluetooth device.
  • On the headphones, press and hold the volume up button and power button simultaneously for 5 seconds.
  • The LED indicator should flash red three times.
Faulty Battery
If encountering problems with holding power or charging, the battery may be faulty. Follow the step-by-step directions in Anker Soundcore Life Q20 Battery Replacement to replace the battery.
Faulty Charger
The charging cord and block for the headphones may be faulty or broken.
  • Leave the headphones plugged in for 24 hours to see if they charge.
  • Test the charger with another device to ensure that the charger is working properly.
    • If you find that the cable or block of the charger are not working, try another charger. Soundcore recommends that you use a 5V charger.
Faulty Outlet
If all other parts of the headphones are working properly, the electrical outlet may be faulty.
  • Use the same outlet to charge another device to ensure that it is working properly.
  • If the outlet does not charge other devices, try a different outlet.
Olivia S
crwdns2935283:001/30/25crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
Carson-Newman University, Team 1-2, Sobiech Spring 2025 crwdns2935289:0Carson-Newman University, Team 1-2, Sobiech Spring 2025crwdne2935289:0
CNU-SOBIECH-S25S1G2
crwdns2935297:048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 106
crwdns2959996:0crwdne2959996:0 1,647
