crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If the Acer Chromebook CB315-5H-P8HK trackpad will not move the cursor or allow you to click as expected, follow these steps to get your trackpad working again.
Trackpad Disabled or Sensitivity Set Too Low
If the trackpad is not responding or feels unresponsive, it may be disabled or set to a very low sensitivity in the system settings. This can happen accidentally during adjustments or updates. Open the Settings menu, navigate to the Device section, and select Touchpad. Check that the trackpad is enabled and increase the sensitivity if necessary. Restoring these settings can often resolve the issue immediately.
Temporary System or Software Glitch
A temporary software issue can cause the trackpad to stop working even if the hardware is functioning properly. This may occur after the Chromebook wakes from sleep or installs updates. Restarting the device can refresh system processes and restore functionality. If the issue continues, perform a hard reset by powering off the Chromebook, then holding the Refresh key while pressing the Power button. This can clear minor system errors affecting input devices.
Dirty or Wet Trackpad Surface
The trackpad relies on detecting subtle finger movements, so dirt, oil, or moisture on the surface can interfere with its performance. A dirty trackpad may result in delayed, erratic, or no cursor movement at all. Turn off the device and gently clean the trackpad with a soft, lint-free cloth. If necessary, lightly dampen the cloth with isopropyl alcohol. Allow the surface to dry completely before turning the device back on.
External Mouse or Bluetooth Interference
External input devices such as USB or Bluetooth mice can override or disable the built-in trackpad. This can make it seem like the trackpad is not working when it is simply being bypassed. Disconnect any external pointing devices and disable Bluetooth temporarily to check if the trackpad begins working again. If it does, the issue was likely caused by interference or system prioritization of the external device.
Outdated ChromeOS
Running an outdated version of ChromeOS can lead to bugs or compatibility issues that affect the trackpad. Updates often include fixes for hardware input problems and improvements to system stability. To check for updates, open Settings, navigate to About ChromeOS, and select Check for updates. Install any available updates and restart the Chromebook to ensure the changes take effect.
Loose or Disconnected Trackpad Cable
If the trackpad is completely unresponsive, the internal ribbon cable connecting it to the motherboard may have become loose or disconnected. This can happen due to drops, impacts, or general wear over time. Opening the Chromebook and reseating the cable can restore the connection. Care should be taken when handling internal components to avoid causing further damage.
Faulty Trackpad Assembly
The trackpad itself may be damaged or worn out, especially if it has been heavily used or exposed to physical stress. Signs of a failing trackpad include inconsistent cursor movement, failure to register clicks, or a complete lack of response. In this situation, replacing the trackpad assembly is the most effective solution. Installing a compatible replacement part can restore full functionality.
Motherboard or Input Controller Failure
If none of the previous solutions resolve the issue, the problem may be related to the motherboard or its input controller. This type of failure can prevent the Chromebook from recognizing the trackpad entirely. Inspecting the motherboard for signs of damage such as corrosion or burnt components, can help confirm this diagnosis. If a fault is found, repairing or replacing the motherboard may be necessary.
