Phone Will Not Power On
The telephone does not respond or show any signs of powering on.
Power Cord Not Plugged In
Make sure the power cord is securely plugged into the wall outlet and into the back of the telephone. If this does not work, reset the telephone. To do this, unplug the electrical power. Wait for approximately 15 seconds, then plug it back in. Allow up to one minute for the telephone to rest.
No Dial Tone
The display shows no line. I cannot get a dial tone.
Telephone Line Not Plugged In
Make sure you plug the telephone line cord securely and firmly into the telephone and the telephone wall jack
Defective Telephone Line Cord
If the previous suggestions do not work, disconnect the telephone line cord from your telephone and connect the telephone line cord to another telephone. If there is no dial tone on that other telephone either, your telephone line cord may be defective. Install a new telephone line cord.
Defective Telephone Wall Jack
If changing the telephone line cord does not help, the wall jack (or the wiring to this wall jack) may be defective. Try using a different wall jack in your home to connect your CL4940 telephone, or contact your telephone service provider.
System Error
The system may have operation troubles. To solve this, reset the phone by disconnecting the electrical power for about 15 seconds. Then plug it back in and wait for one minute to allow the telephone to reset.
I cannot dial out.
  • Try all the suggestions, as mentioned above.
  • Make sure you have a dial tone before dialing.
Background Noise
  • Eliminate any background noise. Noise from a television, radio, or other appliance may cause the phone to not dial out properly. If you cannot eliminate the background noise, first try moving the telephone before dialing, or dialing from another room with less background noise.
Telephone Service Problem
  • If other phones in your home are having the same problem, contact your telephone service provider.
I hear other calls while using my phone.
Phone Service Disorder/ Wiring Problem
  • Disconnect the telephone from the telephone jack, and plug in a different telephone. If you still hear other calls, call your telephone service provider.
System announces: "Time and Day not set."
Telephone Has Been Reseted
  • You need to set the system clock.
1. Press MENU -> press ▽/△ to scroll to Set date/time -> press SELECT.
2. Use the dialing keys (0-9) to enter the month (MM), date (DD) and year (YY) -> Press
SELECT.
3. Use the dialing keys (0-9) to enter the hour (HH) and minute (MM).
4. Press ▽/△ to select AM or PM -> press SELECT to save your setting.
You can press CANCEL to go back to the previous field and make correction.
I get noise or static when I use the telephone base.
DSL Internet Service Interference
  • If you subscribe to high-speed internet service (DSL - digital subscriber line) through your telephone line, you must install a DSL filter between the telephone line cord and the telephone wall jack. The filter prevents noise and caller ID problems as a result of DSL interference. Contact your DSL service provider for more information about DSL filters.
Telephone Installed Near Other Electronic Devices
  • Do not install this phone near a microwave oven or on the same electrical outlet. You may experience decreased performance while the microwave oven is operating.
Modem/ Surge Protector Problems
  • If you plug your phone in with a modem or a surge protector, plug the phone (or modem/surge protector) into a different location. If this does not solve the problem, relocate your phone or modem farther apart from one another, or use a different surge protector.
Charles Moore
crwdns2935283:002/16/16crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-2, Harley Spring 2016 crwdns2935289:0IUPUI, Team 2-2, Harley Spring 2016crwdne2935289:0
IUPUI-HARLEY-S16S2G2
crwdns2935297:048crwdne2935297:0
crwdns2944067:063crwdne2944067:0
My phone does nor ring on incoming calls. Please help to solve the problem
Hugo Davila - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have 4 att CL4940 phones. No one rings when receiving incoming calles.
Display has broken characters for caller ID - impossible to read. Are there batteries to this phone?
Connie Springer - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
unplug from the phone jack & power supply or remove the battery to reboot the memory.
you'll have to reset all previous settings.
if the cid is still unreadable, your phone got fried by a power hit & it probably can't be fixed.
KLF - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 13,951
