crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Laptop won't turn on
“My laptop won’t turn on”
Drained battery
If your laptop does not turn on, it may not be charged.
Bad display
If you cannot see the screen, the brightness might be low
Bad logic board
If you cannot turn the laptop on, the board may not be connected properly
Bad trackpad
“My trackpad is unresponsive”
Make sure the trackpad is enabled
If your trackpad is not responding, you may have accidently disabled it
Trackpad may need to be calibrated
If your trackpad is not working properly, it may have to be recalibrated
If all else fails, you may need to replace trackpad
If the above solutions did not fix the problem, then the trackpad may be defective and may need to be replaced
Malfunctioning Keyboard
“My ‘L’ key won’t work”
Make sure the keyboard cables are attached to the motherboard
If your keys are not functioning properly, the wires may not be connected to the motherboard correctly
The keys may need to be cleaned
If your keys are not functioning properly, use a keyboard air duster to remove particles from beneath the surface
No sound from speaker
“I can’t hear the music out of my laptop”
Make sure you have not accidentally muted the sound option
If you cannot hear any sounds, you may have accidentally muted the speakers
Make sure the speakers are clean and clear of any dust
Sometimes dirty speakers have problems producing sounds so clean them to get rid of any problems
crwdns2935291:0crwdne2935291:0
Cindy Lopez
crwdns2935283:010/13/15crwdne2935283:0
654 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 1-3, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 1-3, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S1G3
crwdns2935297:048crwdne2935297:0
Right hinge support broken.
After a search on google, it seems to be a common problem on Asus UX series : On sceen side, the hinge is screwed in plastic frame, and because of fatigue, the plastic will break.
When it happens, the screen cover case is the piece to change ($80-$90), and the hinge may be replaced too ($15-$20 each). Some lubricant may be required to ease hinge movements.
Now : How to replace cover case ? In my case I have a touchscreen, and the piece and manipulation are not the same.
oresias - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 46
crwdns2959996:0crwdne2959996:0 3,641
