crwdns2862637:0crwdne2862637:0
crwdns2869081:0crwdne2869081:0
ASUS ExpertBook B1402CGA Running Slowly
The laptop operates slowly, freezes frequently, or takes longer opening applications.
Too Many Background Applications
Running multiple applications can consume excessive memory and processing power. Press Ctrl + Shift + Esc to open Task Manager. Select Processes to view active applications and their resource usage. Close unnecessary applications consuming excessive CPU or memory. Disable unnecessary startup programs to improve performance. Restart the laptop and check whether performance improves.
Insufficient Storage Space
Limited storage space may reduce the laptop's overall performance. Open File Explorer and select This PC. Check the available storage space on the main drive. Delete unnecessary files and uninstall unused applications. Empty the Recycle Bin to recover additional storage space. Restart the laptop and check its performance.
Outdated Software or Drivers
Outdated software can cause compatibility problems and slow system performance. Open Windows Settings and select Windows Update. Download and install all appropriate available updates. Visit ASUS Support for compatible driver updates. Restart the laptop after completing the updates.
Faulty or Insufficient RAM
Insufficient RAM can cause freezing, slow performance, and application crashes. Open Task Manager and select the Performance tab. Check memory usage while running normal applications. Run Windows Memory Diagnostic to check for memory problems. Replace the RAM module if testing confirms a hardware failure. Follow the ASUS ExpertBook B1402CGA RAM Replacement Guide.
crwdns2935291:0crwdne2935291:0
Dylan Sutphin
crwdns2935283:010/19/26crwdne2935283:0
51 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Purdue University Northwest, Team 1-2, Hardin Fall 2026 crwdns2935289:0Purdue University Northwest, Team 1-2, Hardin Fall 2026crwdne2935289:0
PNW-HARDIN-F26S1G2
crwdns2959996:0crwdne2959996:0 17
