crwdns2862637:0crwdne2862637:0
crwdns2869081:0crwdne2869081:0
ASUS ExpertBook B1402CGA Overheating
The laptop becomes excessively hot, produces loud fan noises, or shuts down.
Blocked Air Vents
Blocked air vents can prevent heat from escaping the laptop. Place the laptop on a hard, flat surface. Avoid using the laptop on blankets or soft furniture. Inspect the ventilation openings for dust or debris. Shut down the laptop before cleaning the vents. Carefully remove visible dust using appropriate electronics-cleaning tools.
Excessive CPU Usage
High CPU usage can cause excessive heat during normal operation. Press Ctrl + Shift + Esc to open Task Manager. Select Processes and check the CPU usage percentages. Identify applications consuming excessive processing power. Close unnecessary applications to reduce processor activity. Allow the laptop to cool before continuing normal operation.
Dust Accumulation Inside the Laptop
Dust buildup can restrict airflow through the internal cooling system. Shut down the laptop and disconnect the power adapter. Follow the ASUS ExpertBook B1402CGA Lower Case Removal Guide. Disconnect the internal battery following ASUS service instructions. Carefully remove dust from accessible cooling components. Prevent the fan from spinning during cleaning. Reassemble the laptop and check whether overheating continues.
Faulty Cooling Fan
A malfunctioning fan may prevent the laptop from cooling properly. Listen for unusual grinding noises or excessive fan noise. Check whether the fan operates when cooling is required. Shut down the laptop if overheating continues. Replace the fan assembly if testing confirms a hardware failure. Follow the ASUS ExpertBook B1402CGA Fan Assembly Replacement Guide.
