Prerequisite only! Use this guide to remove the motherboard cover in your Xiaomi Redmi Note 8T.
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right side to cut the remaining adhesive.
Carefully fold the rear glass to the right side of the phone. Use the suction handle as a stand for the rear glass.
Use a spudger to pry up and disconnect the fingerprint flex cable.
Remove the rear glass.
Remove the eleven Phillips #00 screws (3.9 mm length).
Insert the tip of an opening pick underneath the bottom edge of the motherboard cover.
Use the opening pick to pry up the motherboard cover.
Remove the motherboard cover including the black protective foil that covers the battery.
