for this teardown you will need a potato found in any supermarket or can be grown in your own vegetable patch
First you will need to wash your potato with water.
Then you will need to peel your potato with a potato peeler.
Preheat your oven to 200 degrees Celsius then put your potato chunks on an oven tray and bake for 30 to 45 minutes.
Does this hurt the potato?
The potato is no longer alive at the time you buy it at the grocery store
LucWag1 -
It actually revives it's self, when it wants to reproduce.
How easy is the re-assembly, do I need a Torx driver?
