crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0iPhone 12crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. iPhone 12  Teardown, Remove the SIM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the SIM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SIM Card tray using a SIM Card eject tool
  2. iPhone 12  Teardown, Unscrew the lower screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Unscrew the lower screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Unscrew the lower screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the device
    • Unscrew the two 6.9 mm long Pentalobe screws.
  3. iPhone 12  Teardown, Raise the display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Raise the display: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Raise the display: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a heated iOpener all around the edge of the screen to loosen the adhesive under the display.
    • Lift the display with a suction cup and insert a thin object to separate the screen from the frame.
    • Slide the fine object along the entire edge to cut the adhesive.
    • Raise the display.
    Please explain what you mean by heated iopener on each edge. The link doesn’t work for me. Thank you
    William - crwdns2934203:0crwdne2934203:0
  4. iPhone 12  Teardown, Disconnect the display: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Disconnect the display: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Disconnect the display: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 6 Phillips # 00 screws.
    • With a spudger or with your fingernails, lift the two connectors.
    • Lift the connector underneath.
    • Disconnect the display connector.
  5. iPhone 12  Teardown, Remove the rear camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Remove the rear camera: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Remove the rear camera: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 4 Phillips # 00 screws.
    • With a spudger or fingernails disconnect the two rear camera connectors.
    • Remove the rear camera.
    These are not Philips head screws, they are tri-wing, and also there is an actual Philips head screw at the very top of the plate that also needs removal
    Dominic Goncalves - crwdns2934203:0crwdne2934203:0
  6. iPhone 12  Teardown, Remove the front camera.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the front camera.: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a spudger or fingernails to disconnect the three connectors that connect the front camera.
    • Remove the front camera.
  7. iPhone 12  Teardown, Remove the battery holder: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the battery holder: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a spudger or fingernails disconnect the battery holder connector.
    • Unscrew the 3 Phillips # 00 screws.
    • Remove the battery holder.
  8. iPhone 12  Teardown, Remove the camera flash: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a spudger or fingernails disconnect the rear camera flash connector.
    • Unscrew the 2 Phillips # 00 screws.
    • Remove the rear camera flash.
  9. iPhone 12  Teardown, Remove the SIM card holder: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Remove the SIM card holder: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Remove the SIM card holder: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 2 screw holders with the suitable screwdriver.
    • With a spudger or fingernails to disconnect the SIM card holder connector.
    • Remove the SIM card holder.
  10. iPhone 12  Teardown, Remove the battery logic board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the battery logic board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 Phillips # 00 screws.
    • With a spudger or fingernails disconnect the 3 battery connectors.
    • Unscrew the screw holder with a standoff screwdriver for iphone.
    • Remove the film with a spudger.
    • Attention this last step is necessary to remove the logic board.
    • Remove the logic board.
    There is an additional screw at the very top that needs removal
  11. iPhone 12  Teardown, Remove the speaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the speaker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 5 Phillips # 00 screws.
    • Remove the speaker.
  12. iPhone 12  Teardown, Remove the taptic engine: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the taptic engine: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 screw holders with a standoff screwdriver for iphone
    • Remove the taptic engine connector with a spudger or fingernail.
    • Remove the taptic engine.
  13. iPhone 12  Teardown, Remove the battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the adhesive under the battery.
    • To remove the adhesive under the battery, remove the stickers marked in red in the first photo.
    • Remove the battery.
  14. iPhone 12  Teardown, Remove the charging port: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the charging port: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew 6 Phillips # 00 screws.
    • Remove the 4 screw holders with an iPhone standoff screwdriver.
    • Attention, the previous step is essential to remove the charging port.
    • Remove the charging port.
    • Be careful not to make too strong, this could damage some components.
  15. iPhone 12  Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • And here are all the components that make up the new iPhone 12.
crwdns2934873:0crwdne2934873:0
it en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Andrea Alfani
crwdns2935283:004/20/22crwdne2935283:0
8 323 crwdns2915208:0crwdne2915208:0
Kid fixers crwdns2935289:0Kid fixerscrwdne2935289:0
Community
crwdns2931471:0188crwdne2931471:0
crwdns2935297:0274crwdne2935297:0
crwdns2947412:07crwdne2947412:0
I had problem with nfc. When it was changed. Have any solution?
Ak H - crwdns2934203:0crwdne2934203:0
I don't see any mentioning of the microphone, Is the Microphone an integral part of the charging port harnes?
Paal Halvorsen - crwdns2934203:0crwdne2934203:0
This guide is missing A LOT of steps
Jason Oestrike​ - crwdns2934203:0crwdne2934203:0
This is definitely not a US iPhone 12! e careful as the antenna can tear easily and potentially ruin a motherboard.
Kyle Morrell - crwdns2934203:0crwdne2934203:0
>disconnect battery connector
>disconnetct 3 battery connectors
wtf?)) why do you call any FPC "battery connector"? so NPC
Джокер Богданофф - crwdns2934203:0crwdne2934203:0
not very detailed, many steps are missing
tryndes - crwdns2934203:0crwdne2934203:0
Step 7: "Remove the battery holder"
That's not a "battery holder (?)" that's the Bluetooth antenna/cable. It's also glued to another cable that is soldered to the bottom of the main board, goes around the top of the battery and down the right side. That cable seems to be missing entirely here.
SS IT Support - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 43
crwdns2936753:07crwdne2936753:0 420
crwdns2936753:030crwdne2936753:0 1,899
crwdns2942667:0crwdne2942667:0 50,767
