crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Hp Pavilion dv9363eacrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. hp laptop dv9000 serie dv9363ea Teardown, hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown, hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • first of all, if you start to work on your laptop make a plane of the screws. Use an magnetic project board. or just paper and tape and draw the plan.
    • remove the battery, and the 3 panels.
  2. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • remove the RAM and the HDD.
    • to remove the hdd just lift it up. ( its an sata hdd but they use an IDE adapter.
  3. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove the wifi pci-e card and the antennas.
    • it will come out of the screw sockets when you remove the srews.
  4. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • now we will remove the dvd rw drive.
    • first remove the screw at the back of the laptop (bottom) see first picture
    • than use a spudger to slide the dvd drive away of the laptop.
  5. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • in this step we will remove the keyboard.
    • there are 10 screws to remove in total. 1 screw on the botoom plate , 6 screws in the battery compartment and 3 under the grey plastic board above the keyboard.
    • first remove the black screw on the bottom , it's next to the screw of the dvd drive.
    • than remove the 6 grey little screws of the battery compartment.
    • then remove the grey plastic board above the keyboard. see picture 3, to be continued in the next step
  6. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • if you remove the grey plastic board be carefull for the wire and socket
    • than remove the other screws from the keyboard. see picture 2
    • now you can remove the keyboard.
  7. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the rest of the screws of the bottom plate.
    • like i said before, make a plan of the screws and parts. it's easier to put it back together
  8. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • now remove all the other screws on the upper case. (under the keyboard)
    • also remove the cables/wires.
    • the power board is in the left upper corner. be carefull with the sockets.
    • some wires are taped or glued so be carefull.
  9. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • if every screw and wire is loose then you are ready to remove the grey plastic board (arround the keyboard)
    • slide the spudger arround the case. it's very easy to remove. just hear the clicks.
    • after removing this plastic frame , the main board is visible.
  10. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • now we will remove the power PCB
    • first remove the connectors but be carefull they are very breakable. and remove the screw, than remove the PCB
    • then remove the red circled screw
    • the yellow and 3 blue screws are from the screen henges.
  11. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • remove usb boards and sd card reader.
    • the yellow circkled PCB below is the Bluetooth PCB. watch out for the connector.
    • the blue circkled connector is the connector of the sd card reader PCB; be carefull if you remove.
  12. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove the wifi PCB. be carefull for the connectors.
  13. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the PCB for the sound at the side of the frame.
    • remove the loudspeakers and the attached black frame.
  14. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • before we go further with the PCB's , we will remove the screen.
    • remove the screws of the henges at the 2 sides.
    • be carefull with the connectors. i broke the connector of the webcam PCB.
  15. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove the second power PCB.
  16. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the DC jack and usb PCB.
    • again be carefull with the connectors.
    • arround the dc jack is a metal frame. remove it before you remove the PCB
  17. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the DVD Drive PCB.
    • 2 screws are hidden under the black tape.
  18. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • now remove the last screws of the mainboard. I dont have a picture of the screws .. mea culpa..
    • remove the main board.
    • there are litlle black screws arround the fan.
  19. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • in this step we will begin at the main board or motherboard..
    • we will remove the fan and cpu cooler.
    • the cpu koeler is in 2 pieces. 1 for the cpu and another chip. than a fan for the Nvidia chip.
  20. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove and clean the pcu fan. in this laptop was a lot of cat hear, that caused a blocked fan.
    • also put new cpu cooling paste on the chips. ( and processor)
  21. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • now the lcd screen...
    • i don't have to tell you that you have to be careful...
    • remove the black dots ( the screws are under the black dots)
    • if you removed all the screws than use the spudger or isesamo to open the frame. you will hear the clicks..
  22. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the microphone module and the webcam PCB.
    • remove the wifi antennas.
  23. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove all the other screws and henges , so you can remove the lcd screen from the frame.
  24. hp laptop dv9000 serie dv9363ea Teardown: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove the mouse or touchpad module.
Kevin D
crwdns2935283:005/02/14crwdne2935283:0
7 454 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,105
