Apple still dominates the smartwatch business in many parts of the world—but can you get a Watch equivalent for roughly half the price? Xiaomi seems to think yes, so today we’re putting their Mi Watch under the knife. Let’s tear it down and see what turns up.
Stay up-to-date on the latest teardowns and repair news—check out our YouTube channel, follow us on Instagram, Twitter, or Facebook, and subscribe to our newsletter for exclusive teardown content.
While the Mi Watch bears a certain superficial *ahem* similarity to a familiar Apple product, we suspect the parallels end there. How fruity are these specs?
Aluminum case with a 1.78" Super AMOLED screen
Snapdragon Wear 3100 platform
1 GB RAM and 8 GB storage
Speaker and microphone for calls (via e-SIM)
Steps counter, sleep tracker, optical heart rate sensor, WiFi, GPS, NFC, and Bluetooth 5.0
You also get MIUI for Watch, a skinned version of Wear OS that can be paired with the Google app in English without problems. (But since there's no international version of the watch, you’d have to get by with Chinese characters on the watch itself.)
Let's compare a little more closely—we wouldn't want to tear down a stunt double by mistake. That's the Mi Watch on the left, Apple Watch Series 5 on the right.
It’s the slight differences that give away the Mi Watch:
A boxier, edgier case, screen, and "digital crown"
A wider black bezel around the display, and a taller profile to match
Charging contacts on the rear, and flappy protruding mounts for the detachable band.
crwdns2935267:0crwdne2935267:0iFlex Opening Tool$11.99
The only external screws fix the band mounts to the case—and removing those reveals the model number, XMWT01. We're pretty sure the rest says "Made in China" by "Xiaomi Communication Technology Co., Ltd." Sounds all too plausible if you ask us.
After applying much heat, and swiping unsuccessfully with the curved razor blade we normally use for Apple Watch incursions, we switch to the thin and sturdy iFlex—along with some off-label use of the iMac Opening Wheel.
What screw driver size do i need to remove the screws for the band mounts?
crwdns2935267:0crwdne2935267:0iFixit Precision Bit Driver, Aluminum$9.99
The screen won't detach quite yet, but its flex cable is lengthy enough that we can maneuver our Precision Bit Driver into position to loosen a bracket and unplug the display.
This is a 1.76" Super AMOLED display with 368 x 448 resolution, and a small circular cutout in the bottom right for the light sensor to peek through.
On the back of the screen, we find a TMA525C 34FNI (PMI 1907 D 21 8/1856) multi-touch capacitive touchscreen controller from Cypress.
For comparison, here's an Apple Watch Series 5 LTPO OLED (to the right), measuring 1.78" with the same resolution.
Next out is the motherboard, with the battery piggybacking along for the ride.
The Mi Watch power cell (left) packs in 2.167 Wh (560 mAh @ 3.87 V), which in terms of sheer capacity leaves the 1.129 Wh from the 44 mm Apple Watch Series 5 (right) far behind.
On the motherboard we discover some interesting silicon:
Kingston 8GB LPDDR3 with Qualcomm MSM8909W layered underneath—also known as Snapdragon Wear 3100 with 32-bit, quad-core ARM Cortex A7 CPU and Adreno 304 GPU
Qualcomm QCC1110 co-processor
Qualcomm PMW3100 power management sub-system
Vanchip VC7643-26 Cellular Front-End Module
Goodix TFA9897 Class D audio amplifier
Qualcomm WCN3620 wireless connectivity chip
NXP Semiconductor PN80T NFC Controller w/ Secure Element
“T9897 music audio IC” is the (formerly) NXP TFA9897:
GTO_S068 : Gemalto eSIM based on STMicroelectronics ST33 J2M0 secure chip
The midframe carries the speaker with its red rubber gasket, buttons for the crown and home button, as well as a small linear resonant actuator.
Again, compared with the Taptic Engine from the Apple Watch, this LRA is only a fraction of the size. What does that mean in terms of vibration force—what’d be their score on a Richter scale?
crwdns2935267:0crwdne2935267:0Tweezers$4.99
At the very bottom of the watch barrel, our blunt nose tweezers helps safely extract the final circuit board, equipped with:
The heart rate sensor and LEDs
Four data and charging contacts
Two microphones
And an optical encoder for reading the crown’s rotation.
Our excursion into the first smartwatch directly from Xiaomi is now complete.
Let’s see how this wrist companion performs in our repairability rating.
- The bands are easy to remove and replace.
- Battery replacement is fairly straightforward once you're inside, but the motherboard must be removed for access.
- Most components are modular and can be replaced separately, except for the circuit board at the bottom—which is secured with plastic rivets.
- Opening the watch by removing the screen is possible, but difficult—and will most likely result in cosmetic damage.
crwdns2935195:0crwdne2935195:0
crwdns2935097:0crwdne2935097:0
crwdns2935199:0crwdne2935199:0
crwdns2944067:07crwdne2944067:0
A new teardown nice!
Thanks for this great Teardown!
Bravo pour ce démontage.
Why not try a MiPosaur Teardown? It involves many parts and a good number of screws. It also involves no adhesives and only the battery terminal slips and speaker are soldered to the motherboard. If you do it, bring different-sized screwdrivers and a sorting tray! You may also want to bring a soldering iron if you want to remove the speaker.
Your glass opener sucks - it is too thick - I had it - too thick compared to my Watch opening tool - yes my tool is maybe more flexible but much thiner and sharper
For some reason my mi watch screen stays all black while the touchscreen is completely fine. is this a software issue or even fixable?
Ha I have a fack iWatch and I want to change it motherboard to mi watch motherboard … my watch modal is t55+ can any one help me out
