crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Withings GO activity trackercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Withings GO Teardown, Unboxing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From left to right: silicone wristband, clip, tracker and plastic coin to open the casing
  2. Withings GO Teardown, Removing the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Withings GO Teardown, Removing the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Withings GO Teardown, Removing the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can simply open the back of the casing with the included tool or with a regular coin to remove the battery
    • The battery that is used is a Panasonic 3V CR2032 with a capacity of 225mAh
    • Removing the battery also exposed a seal ring used to make the enclosure waterproof.
    • FCC ID: XNAWAM02
  3. Withings GO Teardown, Opening the tracker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Withings GO Teardown, Opening the tracker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The casing itself consists of three parts: the top, the bottom and a thin cover for the e-ink display.
    • Separating the parts seemed tricky at first, because they were sealed together, but by chipping some plastic off the side with my utility knife I managed to create a small opening. After that, I could easily cut open the casing around the seam.
  4. Withings GO Teardown, PCB: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Withings GO Teardown, PCB: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Withings GO Teardown, PCB: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The PCB was manufactured by a Chinese company called PLOTECH
    • The back of the PCB immediately shows a bunch of testing points which are labelled on the silkscreen layer with TPXX.
    • The connectors Withings used are called "Front Flip FFC/FPC Connectors" and are very easy to open with a pair of tweezers. (FFC stands for Flat Flexible Cable).
    • Between the e-ink display and the PCB there is a support frame installed, this to keep the display in place and to avoid contact between the display and the PCB components.
  5. Withings GO Teardown, Push button: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the top side of the PCB, in the middle, there is an SMD push button. The display is so thin and flexible you can actually press the button with it.
    • The button is used to set-up the tracker when you unbox it and to switch from "tracker"-view to "watch"-view while using it.
  6. Withings GO Teardown, Accelerometer: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Withings GO Teardown, Accelerometer: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The ultra low-power 3-axis accelerometer on the board is the ADXL362 from Analog Devices (datasheet).
    • Next to the accelerometer there is another chip, a push button reboot controller XC6190 (datasheet).
  7. Withings GO Teardown, Bluetooth radio: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Withings GO Teardown, Bluetooth radio: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Withings GO Teardown, Bluetooth radio: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The bluetooth chip Withings has chosen is the nRF51822 from Nordic Semiconductors. It's a 2.4GHz ultra low-power bluetooth chip built around a 32-bit ARM® Cortex™ M0 CPU.
    • The big white SMD component you see on the right side of the PCB is an RF ceramic chip antenna from Johanson Technology (datasheet).
    • Below the bluetooth chip there are two crystal oscillators. According to the datasheet of the nRF51822 the system uses 2 clocks: A high frequency clock (HFCLK) and a low frequency clock (LFCLK). The HFCLK is fixed to 16 MHz and the LFCLK is fixed to 32.768 kHz.
    • The balun, BAL-NRF02D3 (datasheet) from STMicroelectronics, next to the bluetooth radio is used to match the impedances. This balun is actually optimized for the nRF51822. Read this blog post to understand why a balun is used in this circuit: https://devzone.nordicsemi.com/blogs/655...
  8. Withings GO Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The big black "blob" (glob-top) on the top of the PCB, is what I assume the display driver. The blob is actually a protective cover for the chip and the wire-bonds. This type of method is called "chip-on-board" (COB). Black epoxy resin is used as the chips can be sensitive to light, it's the same material used for the packaging of ICs.
    • You can find a very nice article on Sparkfun on how these types of chips are made: https://learn.sparkfun.com/tutorials/how...
  9. Withings GO Teardown, E-ink display: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Withings GO Teardown, E-ink display: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The display is only 0.45mm thick, that's very thin! The display does contain a serial number "SCD72E00-160418-1". The company eink is the manufacturer.
    • The cool thing about e-ink displays though is that they keep displaying their last state even if they are not connected to a battery. The ultimate proof that these displays are ultra low-power.
November Five
crwdns2935283:008/25/16crwdne2935283:0
465 crwdns2915208:0crwdne2915208:0
I have a bunch of CR2025 batteries, because I use them in various other devices. Could I use CR2025 in Withings Go instead of CR2032?
I for sure know about the difference in capacity and thickness.
Life expectancy of CR2025 could be approx 5-6 months I think.
I just ask you if it is possible in respect of adaptability of contacts in battery holder or its mechanism.
Jiří Sedláček - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,626
