crwdns2936621:0crwdne2936621:0
crwdns2931587:0crwdne2931587:0
crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0WebScreencrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. WebScreen Teardown, Remove the Side Screw from the Enclosure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Remove the Side Screw from the Enclosure: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Remove the Side Screw from the Enclosure: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Description: The side screw secures the enclosure and must be removed first.
    • Action: Use a precision screwdriver to remove the M1.5 side screw.
  2. WebScreen Teardown, Remove the Bottom Cover of the Enclosure: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Remove the Bottom Cover of the Enclosure: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Remove the Bottom Cover of the Enclosure: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Description: Removing the bottom cover provides access to the interior of the WebScreen.
    • Action: ○​ Carefully slide off the bottom cover. ○​ Pay special attention to the power button, ensuring it is not lost if it becomes detached.
  3. WebScreen Teardown, Lift the Electronic Board (PCB): crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WebScreen Teardown, Lift the Electronic Board (PCB): crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Description: The main PCB must be lifted carefully to avoid damaging the flexible connectors.
    • Action: Hold the edges of the PCB and gently lift it.
  4. WebScreen Teardown, Remove the M1.5 Screw to Release the Upper Enclosure: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WebScreen Teardown, Remove the M1.5 Screw to Release the Upper Enclosure: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Description: An M1.5 screw secures the upper enclosure and must be removed to release the display.
    • Action: ○​ Locate and remove the M1.5 screw. ○​ Ensure that the display is completely free.
  5. WebScreen Teardown, Remove the Upper Enclosure: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Remove the Upper Enclosure: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Remove the Upper Enclosure: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Description: With both elements removed, the PCB connected to the display is now accessible.​
    • Action: ●​ Separate the enclosure pieces. ●​ Check the orientation of the PCB and display connectors.
  6. WebScreen Teardown, Remove the PCB along with the Connected Display: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Remove the PCB along with the Connected Display: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Remove the PCB along with the Connected Display: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Description: With the enclosure disassembled, the PCB along with the display can be removed as a single unit.
    • Action: ●​ Carefully hold the PCB and display, ensuring there are no forced connections. ●​ Slowly lift both components at the same time.
  7. WebScreen Teardown, Disconnect the Display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Disconnect the Display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WebScreen Teardown, Disconnect the Display: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Description: With the PCB removed from the enclosure, the display can now be disconnected.​
    • Action: ●​ Use anti-static tweezers to gently disconnect the display’s flex cable. ●​ Ensure there are no active connections before fully removing it.
crwdns2935103:0crwdne2935103:0
HW Lab
crwdns2935283:001/26/25crwdne2935283:0
160 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 285
