Western digital Hard drive tear down
Remove four screws and circuit board lifts out
Motor contacts
Head contacts
Remove 6 perimeter screws
Remove screw from under sticker
Lift cover off
Inside of hard drive
Desiccant packet removed from lower right corner
Inside of cover
Head in dock
Head on disk
Dock removed
Head before bridge removed
Remove two screws
Lift bridge away
Stops to limit head travel
Red coil over magnet cause the head to rotate
Contact block installed
Remove two screws, contact block is now loose but connected to head by a ribbon cable
Disk installed
Remove 3 screws holding down collar
Remove collar
Lift disk out of case
Collar after removal
Head installed, simply lift head out of case
Remove head
Case without head
Removed head
Contacts for data and head control
Head interface to disk
Remove magnet
Remove stop for head on disk
Remove head docked stop
All components arranged
Well done Wieli! Your photographs are very clear and well lighted. Should you decide to edit the guide may I suggest (1) you add what screwdriver tips you used to remove screws and (2) at step 10, highlight the three screws. The screw tips blend in with the collar.
