crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0ViewSonic VG2438Smcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. ViewSonic VG2438Sm Teardown, Type Label: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Model No. VS15964
    • Remove the stand by unscrewing the four Philips screws at the Vesa mount
  2. ViewSonic VG2438Sm Teardown, Open Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ViewSonic VG2438Sm Teardown, Open Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the case by prying on the edge with a suitable tool. I had to use a a opening pick to open the gap wide enough to be able to insert a flat screwdriver.
    • After inserting the screwdriver or a jimmy, bend the handle to the backside of the monitor. So that you lift the front bezel from the hooks and free it.
    • After opening two edges, be careful, since the panel and the logic board are only held in place by the closed case.
    • You probably will damage the case a bit during the process.
  3. ViewSonic VG2438Sm Teardown, Flip the Case Open: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ViewSonic VG2438Sm Teardown, Flip the Case Open: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the back side of the case to the right
    • Be careful with the wire to the USB hub. It's just long enough to flip the case and lay it down.
  4. ViewSonic VG2438Sm Teardown, Panel Details: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • A Samsung LTM240CL04 panel
    • 1920(RGB)×1200, WUXGA 94PPI
    • Active Area 518.4(W)×324(H) mm
  5. ViewSonic VG2438Sm Teardown, The Logic Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is the PSU and the logic board.
    • This is not secured against the panel. It's only laying on it and is held in place by the back side of the case.
  6. ViewSonic VG2438Sm Teardown, USB Hub: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The USB Hub is a separate module
  7. ViewSonic VG2438Sm Teardown, The Opening Reason: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ViewSonic VG2438Sm Teardown, The Opening Reason: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After this monitor was shipped there was a lose thing, that was making sound when moving the monitor.
    • Since I didn't know what was making the sound and it could have been conductive, I wanted to check the inside before powering it up. Thankfully it were only some plastic things.
    • They probably came lose from the back cover, where they hold the logic board in place.
Quanten
crwdns2935283:005/21/18crwdne2935283:0
1.016 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 945
