I got my hands on a defective Tesla Model X key fob, so naturally I wanted to take it apart.
Open the bottom using the method to change the battery
Pull down on the bottom of the back of the 'car' to pull the battery cover off
Use a metal spudger to unhook the three clips on each side, front, middle, and back
You may have to pull down on the bottom to release the small ledges holding on the side
Release the four clips that have been revealed on the sides
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull out the button standoffs with some tweezers
They just slide right out!
Pop the buttons out with some tweezers and remove top and PCB
There you have it!
And no glue!
To reassemble, go in reverse
Neat look inside the most unique key fob in recent memory. Thanks for posting!
The only thing that's missing is a rundown of the ICs on the board. If you don't mind, can you add a close-up of each side of the board and write out the numbers inscribed on each package? Armed with that info, we can see what parts and vendors Tesla used in the key fob, and this is one of the things I find most interesting.
Added images to the last step! :)
scrypt -
Anyone know of any custom enclosures for the fob? As it is stock, it can be dangerous. While hooking up a trailer to my boss’s Model X, the fob was activated by the pressure of my pants while crouched down and hooking up the safety chains, activating Summon. Luckily, the car didn’t move, but it did power up and start flashing the hazard lights, meaning it was ready to move if the front or back buttons would’ve been pressed.
It’s neat that the fob is a miniature car, but the convex shape makes it too easily activated by mistake. The buttons need to be concave in shape so they don’t get pressed by anything else than a finger.
The car should have sensors that prevent it from moving
No Name -
