Teardown of IBM ThinkPad i Series 1200
  1. Teardown of IBM ThinkPad i Series 1200, Drums: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, ensure the notebook is powered off.
    • Unplug the power cord.
    • To remove it, slide the two switches in such a way that it is unlocked, as shown in the picture, and then remove it.
  2. Teardown of IBM ThinkPad i Series 1200, HDD (Hard Drive): crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200, HDD (Hard Drive): crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw in the lower corner.
    • Remove the "cover" of the disk.
    • Pull the "hook" that is attached to the disc to remove it.
  3. Teardown of IBM ThinkPad i Series 1200, RAM cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200, RAM cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the indicated screw from the backside of the notebook.
    • Take off the cover that protects the RAM memory.
  4. Teardown of IBM ThinkPad i Series 1200, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the screen and lay it off the side in a flat manner.
  5. Teardown of IBM ThinkPad i Series 1200: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the indicated screws on the backside of the PC.
  6. Teardown of IBM ThinkPad i Series 1200: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the keyboard down so that the covers from above aren't blocked and as so we will be able to remove them more easily.
    • Don't pull too hard as this can cause the flex cables to break.
    • Disconnect the two ribbon cables that are located on the underside of the keyboard.
    • The back up battery will be connected on the upper middle part.
  7. Teardown of IBM ThinkPad i Series 1200, Internal RAM: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three indicated screws from the backside.
    • It is to be note that these screws are located under protective rubber caps.
  8. Teardown of IBM ThinkPad i Series 1200: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the RAM compartment.
  9. Teardown of IBM ThinkPad i Series 1200, Ethernet card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200, Ethernet card: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two indicated screws.
    • Remove the metal protector that is found above the plate.
  10. Teardown of IBM ThinkPad i Series 1200: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Ethernet card.
    • Careful as there's a cable connected that can be accidentally broken.
  11. Teardown of IBM ThinkPad i Series 1200, Optical drive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200, Optical drive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the indicated screws from the backside of the PC.
    • Remove the optical drive by simply sliding it out.
  12. Teardown of IBM ThinkPad i Series 1200, Display: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, remove the plastic components indicated.
    • These components are press-fitted, and thus we will have to remove them with care.
    • Remove the two screws that are found after step one.
    • Remove the plastic protector that is found on the upper part.
  13. Teardown of IBM ThinkPad i Series 1200: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Proceed by removing the two connectors that are found there.
    • Carefully start separating the display from the inferior side of our PC.
  14. Teardown of IBM ThinkPad i Series 1200, CPU: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200, CPU: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic frame that surround the netbook.
    • This component is press-fitted, so you have to remove it carefully so it doesn't break.
    • Remove the metallic protector.
    • Put aside the CPU cooler.
  15. Teardown of IBM ThinkPad i Series 1200, Thermic paste change: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200, Thermic paste change: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean the fan and the old CPU paste.
    • You have to use alcohol and a small tissue.
    • Alcohol is to not be used on any other part that was that aforementioned.
  16. Teardown of IBM ThinkPad i Series 1200: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place new thermic paste and start putting your PC back together.
  17. Teardown of IBM ThinkPad i Series 1200, Dismantling the dislpay.: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200, Dismantling the dislpay.: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once step 13 is completed.
    • Remove the plastic covers that surround the display.
    • It must be done with a guitar "pick" as the plastic covers could break or scratch.
  18. Teardown of IBM ThinkPad i Series 1200: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the indicated screws that hold the led board.
  19. Teardown of IBM ThinkPad i Series 1200, Inverter: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200, Inverter: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teardown of IBM ThinkPad i Series 1200, Inverter: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the indicated screws that hold the metallic covering.
    • Underneath you will find the inverter.
  20. Teardown of IBM ThinkPad i Series 1200: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power supply connectors from motherboard to inverter.
    • Data cables from motherboard to display.
crwdns2934873:0crwdne2934873:0
es en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2935103:0crwdne2935103:0
Gianfranco Grigera
crwdns2935283:011/05/19crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 564
