crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Sony Xperia ZR C5503crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Sony Xperia ZR C5503 Teardown, Sony Xperia ZR C5503 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To teardown, you only need 3 tools:
    • T6 Torx Screwdriver
    • Phillips #00 Screwdriver
    • Plastic Opening Tools
  2. Sony Xperia ZR C5503 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back case.
    • Then remove the battery.
  3. Sony Xperia ZR C5503 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use T6 Torx Screwdriver to remove all screws you can see on the back panel.
  4. Sony Xperia ZR C5503 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use plastic opening tool to get the screen off.
    • Insert opening tool to the bottom edge of the screen. Then go along the edge slowly to separate the screen.
    • Try several times to get an easy point to insert opening tool. Don't force, although this screen is not that fragile.
    • Finally use opening tool to detach the screen panel connector.
    • Perform this step slowly. Be careful with the flex cable.
    "not that fragile" my neither regions, it's as delicate as butterfly wings and glued along the edge to case. Be very careful and gentle.
    Bernhard Holmvik - crwdns2934203:0crwdne2934203:0
  5. Sony Xperia ZR C5503 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Get the partition between screen panel and motherboard out.
    • Firstly, use Phillips #00 Screwdriver to remove all the screws you can see on the partition.
    • Check next step first, don't hurry to pry the partition!
  6. Sony Xperia ZR C5503 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the partition out a little, you can see there's volume button flex cable sticking on the partition panel. So if you pry too hard, these flex cable may be torn.
    • Flip the phone.
    • Lift the black sticky plastic paper slowly and then you'll see the flex cable sticky on the partition.
    • Use plastic opening tool to separate the flex cable.
    • Perform this step gently and slowly in case of tearing it.
  7. Sony Xperia ZR C5503 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now the partition is easy to get out.
    • Then you can see the motherboard.
  8. Sony Xperia ZR C5503 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia ZR C5503 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use opening tool to open connectors on motherboard gently.
    • Volume button / power button flex cable connector
    • Antenna on the left
    • Front camera flex cable connector
    • And another connector on the right
    • That's it!
Xian Chen
crwdns2935283:006/19/14crwdne2935283:0
311 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
Will my phone still be waterproof after this?
stormsaber - crwdns2934203:0crwdne2934203:0
I;m afraid it's not...
Xian Chen -
You'll have to replace all adhesive stickers, it's still won't guarantee it to be completely waterproof afterwards, but chances will be much higher.
Bernhard Holmvik -
Sony Xperia ZR M36h LCD Screen With Digitizer Module Black available on best price
Display Type TFT capacitive touchscreen, 16M colors
Size 4.55 inches (~64.6% screen-to-body ratio)
Resolution 720 x 1280 pixels (~323 ppi pixel density)
Multitouch Yes, up to 10 fingers
Protection Shatter proof glass- Sony Mobile BRAVIA Engine 2
http://www.cellspare.com/sony-xperia-zr-...
Ahmedabad Muslim - crwdns2934203:0crwdne2934203:0
my wifi is not working properly, its works when the phone is placed very close to the router. it may be the cause of some blockage due to dust accumulation inside. so if i open the screen how would i glue it again? as my screen is fine but dust has started to enter into both the cameras. please help
Kaustav Sinha - crwdns2934203:0crwdne2934203:0
my xperia zr got wet since my display donn turning on what should i do
nadeem ansari - crwdns2934203:0crwdne2934203:0
Can I purchase the motherboard for ZR C5503?
anilverma905 - crwdns2934203:0crwdne2934203:0
where can i replace the display ?
Aleksander - crwdns2934203:0crwdne2934203:0
سلام.لطفا شماتیک این گوشی بزارید داخل سایت.تشکر
Sorena Engineer - crwdns2934203:0crwdne2934203:0
My Xperia ZR is almost 8 years old and 3 years back I replaced it with a Xperia XZ1. Haven't used the ZR since then. Now, I thought of using it as a backup spare phone, but find that the ZR is NOT recognising / detecting the SIM. SIM working fine in other phones. ZR NOT detecting ANY SIM of any Carrier. Did hard Reset, yet the issue remains. Can you provide some help?
All other functions are working fine - Touchscreen, Wi-Fi detection, NFC detection, Apps, Speaker, etc
Praveen Gupta - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 19,121
