crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Sony MP-F75Wcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Sony MP-F75W Teardown, Prepare yourself: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Get your tools and a grounding mat and strap ready.
  2. Sony MP-F75W Teardown, Lowering the Disk Tray: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the trigger arm inwards to get the disk tray in the "injected mode".
    • Be careful not to pinch your fingers.
    • Tipp: If you're planning to store the drive long term, you might consider lowering the disk tray beforehand .
  3. Sony MP-F75W Teardown, Removing the Head Stop: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Removing the Head Stop: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Removing the Head Stop: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the retaining clip.
    • Then move the head stop to the rear of the drive to remove it.
    • Make sure, the disk tray is lowered, before attempting this step!
    • Do not bend the head assembly!
  4. Sony MP-F75W Teardown, Removing the Eject Motor Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Removing the Eject Motor Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Removing the Eject Motor Assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the Eject Motor Assembly.
    • Gently unplug it's connector.
    • Lift the Motor Assembly up and remove it.
  5. Sony MP-F75W Teardown, Removing Slide Plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Removing Slide Plate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Removing Slide Plate: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the retaining washers (be careful not to loose them!)
    • Be careful not to loose these washers. They're pretty much unobtainium.
    • Lift the Slide Plate up and remove it entirely.
  6. Sony MP-F75W Teardown, Removing Stepper Motor Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony MP-F75W Teardown, Removing Stepper Motor Assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two brass screws.
    • Gently unplug the Stepper Motor Assembly and remove it.
    • You should never ever unscrew the bolts for the head alignment, undless there's something wrong with it.
  7. Sony MP-F75W Teardown, Removing Head Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Removing Head Assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Removing Head Assembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently unplug the Head Assembly.
    • Unscrew the black screws to remove the Slide-guide shaft.
    • Remove the Head Assembly with utmost care.
    • Do not open the head assembly too far. Doing so might damage ist completely.
  8. Sony MP-F75W Teardown, Removing the Lateral Brackets: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the Lateral Brackets.
  9. Sony MP-F75W Teardown, Removing the Eject Gear Switch Assembly (new design): crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony MP-F75W Teardown, Removing the Eject Gear Switch Assembly (new design): crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew …
    • … and remove the Switch PCB.
  10. Sony MP-F75W Teardown, Removing the Eject Gear Switch Assembly (old design): crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder …
    • … unclip …
    • … remove PCB carefully, not to break the delicate switch.
  11. Sony MP-F75W Teardown, Removing the Eject Motor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony MP-F75W Teardown, Removing the Eject Motor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully unclip the (desoldered) motor.
    • Pay attention to the cable routing!
  12. Sony MP-F75W Teardown, Opening the Eject Gear Box: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Opening the Eject Gear Box: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony MP-F75W Teardown, Opening the Eject Gear Box: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the eject motor.
    • If your motor is of the old design and held together using clips, bend one clip using tweezers or a long flat blade scredriver.
    • Handle all clips with utmost care! You will break them if you push too hard.
  13. Sony MP-F75W Teardown, Disassembling the Eject Gear Box: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony MP-F75W Teardown, Disassembling the Eject Gear Box: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the big eject wheel by pinching the clip and pushing through the connecting rod.
    • Remove the other gears.
    • Be especially careful when opening clips.
    • The small yellow gear is the infamous "cheese gear." It will deteriorate and crumble eventually, thus resulting in a no longer working eject mechanism.
    • You have sucessfully disassembled the complete drive.
Alexander Krause
crwdns2935283:007/13/22crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 1,280
