crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Sony Ericsson Xperia Mini Pro SK17icrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Sony Ericsson Xperia Mini Pro SK17i Teardown, Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn Off the phone :), Remove back cover, battery and simcard + sd card from the phone!
  2. Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Behind the battery, you will have to remove the CE sticker!
    • Remove from Sim-tray and down, it wont break.
  3. Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 7 bolts.
    • Release clickholders, 5 pcs (green). The back should lift up from the surround.
    • Release from the bottom up.
    • Be careful around the camera, as theres a Flex cable right under it, attatched to the logicboard.
  4. Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the Flex cable by lifting the lower end off the logic board, and lift off the back assembly.
  5. Sony Ericsson Xperia Mini Pro SK17i Teardown, Removing the logic/motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the keypad/screen ribbon cable
    • Unclip the camera
    • Unclip the small tabs holding the motherboard down and slide it out.
    • Lift the motherboard up from the opposite side to the usb port
    • To aid removal gently push the motherboard from the keypad side.
  6. Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release Screen flexcable + lift off of adhesive under flexcable!
    • Remove 7 bolts (black ones), holding the slide/screen in place.
  7. Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 3 bolts, top right one is covered, look carefully
    • The Green line, shows where to flick the slide off of the screen assembly!
    • Easiest way: is to flick it at the top, where you removed 2 bolts. It will come off, pretty easy.
  8. Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once slide is removed, you got access to LCD and touch assembly. Easily remove the small flexcable from touch to LCD and take off LCD.
    • If you've got a new LCD assembly, probably no speaker is part of it. In that case don't forget to remove it from the defective assembly (see on the far left) and put it in the new assembly. It is simply mounted with adhesive.
  9. Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD and the Touch glass CAN NOT be separated!!!!!!!!
    • Go to step 10!
  10. Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a thin tool to wiggle the touch screen from the metal+plastic frame, and then throw the lcd + touch screen into the BIN (ONLY IF U NEED TO REPLACE LCD OR TOUCH SCREEN)
    • I hope this 10 step guide helps some of you guys out there!
    • AGAIN:
    • THE LCD + TOUCH GLASS CANNOT BE SEPARATED! BUY NEW ASSEMBLY!
  11. Sony Ericsson Xperia Mini Pro SK17i Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Please scan, and "like".
    • And comment on my guide if you want :)
    • Thanks for watching!
    • <-- #BadNews... This is what happens if you try removing the touch glass from the LCD
ArHerning
crwdns2935283:012/06/11crwdne2935283:0
316 crwdns2915208:0crwdne2915208:0
crwdns2947412:027crwdne2947412:0
@ Step 10: How a new LCD panel with the digitizer are glued again on to the metallic part???
George - crwdns2934203:0crwdne2934203:0
George:
U need a "special" adhesive tape, a thin one, as the kind used for iphone 3GS touch screens.
Or you can buy another kind, it just have to be thin, STRONG and double sided!
What you do is: Cut the adhesive so it fits metal fram, NOT covering the sensors around the top.
After doing so, u fold the flex cables as they were on the old part. There should be some adhesive already on the LCD flex cables, that needs to be removed.
When thats done, you remove the coveredge on the doublesided adhesive tape, and place the touch + LCD firmly on it, now, press and hold for about 30seks, till you belive the touch is holding, mind the corners, press here also!
THEN your done, assemble the phone again, close your eyes and press the power button, hopefully your "lucky" and you got a picture on the screen hehe :D Good luck mate.
contact me on Skype: CRATERHEAD
Best Regards
Apple Repair Herning DNK
Palle Skov
ArHerning -
Thanks so much! I'll probably get this: http://www.amazon.co.uk/Iphone-Touch-Pan...
George -
Åhh yes sir, my bad, the LCD aint glued to a metallic part, but its glued to the touch screen wich CAN NOT be separated!! Just like the iPhone 4, LCD screens + touch.
The touch glass however is softly glued to the "metallic" frame, bo biggie to remove!
Because:
In any case, you will need to buy a LCD assembly with the LCD already assemled with the touch screen!
Here: http://www.ebay.co.uk/itm/280781653630?s...
I will add
ArHerning - crwdns2934203:0crwdne2934203:0
Hey dude...I am in a bad situation..I broke my mini pro some time back and ordered a touchscreen digitizer from here : http://www.ebay.com/itm/OEM-Digitizer-To...
Now, when I gave my handset to someone for repair, he sys me that he cannot change only the touchscreen because its glued badly to LCD and thus, will break even the LCD if he tries to do that. Now, he has made even my phone non usable and bad looking since he broke the touch component badly while repairing. What do you suggest..? Should he try to separate LCD and touch or is it of no use..? Shall I get my money refunded for touchscreen. Why is only then touchscreen being sold if they cannot be separated from LCD..:O..? Shall I better buy the complete assembly..? Please reply ..Thanks
manjo3311 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 111,343
