crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Sonicare Toothbrush HX6930crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Sonicare Toothbrush HX6930 Teardown, Removing internals from toothbrush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonicare Toothbrush HX6930 Teardown, Removing internals from toothbrush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonicare Toothbrush HX6930 Teardown, Removing internals from toothbrush: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the toothbrush has some slots in the bottom that will accept a large flat blade screwdriver, then clamp the screwdriver in a vise, engage the slots on the screwdrive and turn the case until you hear a snap. Then the internals can be pried out easily using a screwdriver. If no slot, use the excellent alternative opening procedure.
    • Have a look to an alternative opening procedure.
  2. Sonicare Toothbrush HX6930 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonicare Toothbrush HX6930 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonicare Toothbrush HX6930 Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Desoldering Pump
    $3.99
    • Remove rubber ckt board cover & pull off the white cap at far left. Then unsolder wires at 6 points shown. While applying heat, extract solder with solder pump & solder wick. Gradually pry ckt board off the soldered points while applying heat. Then pull out the battery from the other side.
  3. Sonicare Toothbrush HX6930 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonicare Toothbrush HX6930 Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonicare Toothbrush HX6930 Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach motor assembly from battery holder. Cut through the spot welds (A Dremel tool and abrasive disk is what I used) and open the clamshell holding the motor assembly. Pull out motor, remove magnet attached to motor stator. This concludes teardown process.
Greg
crwdns2935283:008/23/20crwdne2935283:0
389 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 891
