crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Simoniz 3-in-1 Wand XE27-021-0090crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Simoniz 3-in-1 Wand XE27-021-0090 Teardown, Simoniz 3-in-1 Wand XE27-021-0090 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pictured all labelled parts in exploded view and tools used.
  2. Simoniz 3-in-1 Wand XE27-021-0090 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use punch and hammer to back out metal pins seen here.
  3. Simoniz 3-in-1 Wand XE27-021-0090 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once this pin has been backed out far enough, remove it with channellock pliers. Careful, all internal parts tend to fall out once this pin has been pulled out.
  4. Simoniz 3-in-1 Wand XE27-021-0090 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Simoniz 3-in-1 Wand XE27-021-0090 Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace required part and reassemble. Use channellocks to pinch metal pin to fit it back in the holes. To properlly remove an o-ring, view the following video. For tough to remove o-rings, also pinch it with a cloth. https://www.youtube.com/watch?v=EDiDoJCf...
Tyler
crwdns2935283:001/08/21crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
Having the exact same issue, same washer and the same response from Simonz. Easily taken apart but the washer is impossible to find a replacement.
How has your repair held up with the alternative washer?
Geoff Peterson - crwdns2934203:0crwdne2934203:0
Hey Geoff,
It has held up ok, but has blown out twice more. The local o-ring shop has a minimum purchase of $5, so I got 10 (I could have gotten 100 for $5) and have 7 left. Unfortunate that it isn't a perfect solution, but it works. I have found the best solution is to follow the following steps during operation:
1)Use pressure washer as normal
2) Turn off pressure washer
3) Pull trigger to depressurize hose
4) Change nozzle setting
5) Resume use of pressure washer as normal
Tyler -
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 1,927
