crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Sappire Vapor-X AMD R9 280xcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Sappire Vapor-X AMD R9 280x Teardown, Sappire Vapor-X AMD R9 280x Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Sappire Vapor-X AMD R9 280x Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Sappire Vapor-X AMD R9 280x Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To strip down the GPU you will need a Phillips #0 screwdriver
  2. Sappire Vapor-X AMD R9 280x Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fans and the light connector
  3. Sappire Vapor-X AMD R9 280x Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the pair of screw that join the heatsink to the I/O plate.
    • Note! This pair of screws is unique to this join. Keep them seperate from other screws.
  4. Sappire Vapor-X AMD R9 280x Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 11 screws, those (+ the next 4 screws) work joining the heapsink+fans group to the gpu
    • Note: Ignore 2 empty holes
  5. Sappire Vapor-X AMD R9 280x Teardown, Heatsink removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Heatsink removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Heatsink removal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now release 4 of the screws (Using the star pattern repeating, To evenly dissipate the the force on the die of the Graphics chip) that hold the GPU Core to the heatsink
    • Note this is the clean, thermal paste ready photo
    • This is the 3 years dirty one
  6. Sappire Vapor-X AMD R9 280x Teardown, Fan support removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Fan support removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 4 screws to separate the fans of the heatsink
    • Note these screws are pointed tip for plastic
    • At this point you'll release the heatsink is not very clean
  7. Sappire Vapor-X AMD R9 280x Teardown, Your dirty heatsink: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Your dirty heatsink: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Your dirty heatsink: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is good time to clean the heatsink if it's dirty
  8. Sappire Vapor-X AMD R9 280x Teardown, Release the metal plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Release the metal plate: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Release the metal plate: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3 screws per side (6 screws in total) to release the 2 metal plates
  9. Sappire Vapor-X AMD R9 280x Teardown, Fan and light release: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Fan and light release: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Fan and light release: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3 screws (per fan 9 in total) to release each fan
    • Remove 2 screws that holds the light and fan wires
    • unplug and remove the light
  10. Sappire Vapor-X AMD R9 280x Teardown, Fans remove: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Fans remove: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Fans remove: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At this point you can easy remove the fans
    • Note: the one with the shorter cable and 4 wires is the center one (for the GPU core)
    • the one with double 4 wire connector is the nearest to the gpu outputs
  11. Sappire Vapor-X AMD R9 280x Teardown, final teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, final teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At this point you can easy clean your fans, the fan support (it's plastic) and the plates
  12. Sappire Vapor-X AMD R9 280x Teardown, Re assembly notes: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Re assembly notes: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sappire Vapor-X AMD R9 280x Teardown, Re assembly notes: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • when you're joining the heatsink (plus the fan support), I recommend you put the block on the edge of the table for optimal position
    • Remmember to clean the old thermal paste and replace with a new coat
dfoxpro
crwdns2935283:006/09/12crwdne2935283:0
151 crwdns2915208:0crwdne2915208:0
I have the same card and I find your guide very useful. My problem is that the last fan (at the end where there're the power connectors) only starts spinning at 80%. Do you have any idea how can I fix it?
Péter Friedrich - crwdns2934203:0crwdne2934203:0
Is that what is going on with my EVGA Geforce GTX 970 4gb when it looks like just one of the 2 fans are spinning? I'll have to Google it and see, because I was about to go ahead and do this. Not because it overheats, as 2k scaled to 4k resolution benchmarking never takes it over 79c, maybe touching 80c without throttling. I'm a moon, but I don't think that is hot. Seen 100c/213f on my Lenovo, but it was an i7 processor with switchable graphics from Intel to AMD R9 GPU. And without good ventilation from beneath, it was easy to overheat… was scary!
Anyways, thanks for the likely answer to a question I've had.
Brick Banana - crwdns2934203:0crwdne2934203:0
I had a similar issue with my RX580 right out of the box (damaged in shipping) because the shroud was bent slightly so that the fan was catching. You might want to mess around a bit and see if the fan can spin freely. Best of luck!
Reed Crosby -
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 9,819
