crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Samsung Intensitycrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Samsung Intensity Teardown, Samsung Intensity Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover and battery
  2. Samsung Intensity Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 8 screw that hold the back cover down.
    • Carefully pry back piece off
    • Start at the bottom and work toward the top.
  3. Samsung Intensity Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the ipod opening tool to disconnect the Connector
  4. Samsung Intensity Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Intensity Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the main board
    • Make sure to not tear the microphone cable, pry it from the phone carefully
  5. Samsung Intensity Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Intensity Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 screws
    • Pry to ribbon cable assembly loose from the slider
    • Its glued on the left and right side
  6. Samsung Intensity Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 screw the holds the slider to the phone assembly
    • one of the screws will be behind the hinge
    • Carefully pry slider assembly loose from display assembly
  7. Samsung Intensity Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Intensity Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Intensity Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tape and pop the connectors and pull all the ribbon cables loose
    • Carefully pry the speaker loose from the case.
  8. Samsung Intensity Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully work the keyboard loose from the display assembly
    • There are a couple fragile clips that hold it in place
  9. Samsung Intensity Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Intensity Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • LCD comes out pretty easily
    • Pry it from the bottom and work up the sides to release it if stuck
    • The glass can be removed with a little heat from a heat gun or blow dryer
    • Pry it out from the outside edges working around carefully
David
crwdns2935283:008/10/11crwdne2935283:0
148 crwdns2915208:0crwdne2915208:0
This was so helpful! How can I show my gratitude to you for these helpful instructions?
teh_pwnerer22 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 4,893
