crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Samsung Galaxy S IIcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The 4.3-inch super Amoled Plus display is simply gorgeous!
  2. Samsung Galaxy S II Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Look at how slim the phone is! Only 8.49mm thin!
    • Back cover is flexible but don't worry it will not break. It also has a nice texture to it.
    The plastic cover is elastic, but hardly fragile. You can bend it 180° and it doesn't break.
    Roy Weiss - crwdns2934203:0crwdne2934203:0
    True, I tried to edit the guide to show this information but was denied!
    funkmasterta888 -
    I agree about the back plastic cover, it is very flexible and doesn't break that easily.
    alexman98 - crwdns2934203:0crwdne2934203:0
    Have a look at this video that shows how durable the battery cover is! Thin, light and durable, now we're talking!
    http://www.youtube.com/watch?v=ErXqnQKs-...
    A video about this amazingly thin, light and flexible battery cover! Try and beat that aluminum!
    funkmasterta888 - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy S II Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Look at how compact everything is inside!
    • Remove the seven visible screws.
    • Then unclip the back panel starting on the left next to the audio jack. Go slowly.
  4. Samsung Galaxy S II Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the back panel gives you an impressive and sophisticated view of the internals.
    I’m trying to disassemble my second-hand Galaxy S II and am stuck at this stage.
    A piece of the circuit board directly beneath the audio jack is stuck to the back panel and I don’t want to risk breaking it by prying it off any further.
    Any help would be appreciated.
    [deleted] - crwdns2934203:0crwdne2934203:0
  5. Samsung Galaxy S II Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the motherboard is as simple as it looks !
    • Unclip the 5 ribbon connectors and the antenna cable.
    • Then remove the 2 small black screws.
    • Don't forget to unglue the volume flex and power flex, they are attached to the motherboard. Otherwise the motherboard won't come out easily like it should.
    pry off the glued power and volume buttons before lifting the board because too much pressure will tear the ribbon from the board leading to much heartache
    John McGyver - crwdns2934203:0crwdne2934203:0
    I have a question. Where is the internal SD card located? Is it integrated into the motherboard?
    GrowlyCub - crwdns2934203:0crwdne2934203:0
    Thanks. I tried an external antenna in the port under the cover, to the top left of the battery, and now I get "mobile operator not available" when the antenna isn't in. I've read that a factory reset won't cure this but if I replaced the pcb part that should be me "back to normal"? Thanks
    nathanjh13 - crwdns2934203:0crwdne2934203:0
    I fixed it. Insert a SIM card from another operator, select "Automatic" from the mobile networks and the phone will work. Reboot with your regular SIM back in and choose "Automatic" again and back to normal. People elsewhere say you need a new motherboard (or send to Samsung etc for repair) as it's not possible to solve via software. I tried another SIM to test if it was hardware or software related and it most certainly is solvable via software. Unless I was very very lucky, which I never am.
    nathanjh13 -
  6. Samsung Galaxy S II Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The board with removed EMI shields.
    • The front.
    • ..and the back.
    • The front panel without the logic board.
    • The front facing camera part, the cinch-vibrator-1.mic part and the usb connection-2.mic-antenna board.
    HELP,PLease
    My Samsung S2 I9100G has Hard Brick Problem, for month ago i have visit technical center and they told me "the problem in the the IC" but they didn't specify which model (Power IC or Charger IC or CPU IC)!!
    Iam so confused because i didn't remember where exactly the technical guy pointed to! :confused:
    the expected area of the IC is the right side of the mobile, Please help me to know which part or piece should i buy to make my mobile working again
    please check the photo
    http://imgur.com/cAUF6lM
    Doraid Abo Salem - crwdns2934203:0crwdne2934203:0
  7. Samsung Galaxy S II Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The camera connector is at the upper left corner in the second picture.
    • The power and volume buttons are soldered to the logic board.
    • View the picture in HQ if you want to be impressed!
    You can further enhance your 3g/wifi signal through the use of extension antenna - http://telcoantennas.com.au/site/patch-l...
    Tai Li - crwdns2934203:0crwdne2934203:0
  8. Samsung Galaxy S II Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This EMI shield is nearly a heat sink.
    • Should be useful with a 1.2GHz dual core under it!
  9. Samsung Galaxy S II Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The (tiny) 8MP camera.
    • It's smaller than an iPhone 4 camera.
    Anyways to replace this camera module with Galaxy S3 camera module?
  10. Samsung Galaxy S II Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The front-facing camera and the light sensor are a single part.
    • The front-facing camera is 2MP, which is better than the iPhone 4's VGA camera.
    Can I replace the front camera with another 8 MP back camera?
  11. Samsung Galaxy S II Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The vibrator, first mic (did you know there are two?), cinch plug and the earspeaker.
    I would like to know the part number for the ear speaker please. Thanks
    Hamza Bhavnagarwala - crwdns2934203:0crwdne2934203:0
  12. Samsung Galaxy S II Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The USB-connection and 2 x mic board.
    • It's stuck with glue to the front panel.
    • The (only) antenna cable and a metal shield holding the light sensor in place.
    Hello. How do you actually unglue the USB flex cable ? Do you use chemical products, heat, or simply tear it ?
    rgauthierventre - crwdns2934203:0crwdne2934203:0
  13. Samsung Galaxy S II Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S II Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is it.
    • It still works after reassembly!
    Can you please describe how to replace the home button and the associated OEM Flex Cable Keypad Button Ribbon? I have the home button acting like it is always pressed and I tried to change everything in the phone (hw and sw) but it's still not working right :(
    Roberto Francescangeli - crwdns2934203:0crwdne2934203:0
lon
crwdns2935283:003/19/11crwdne2935283:0
2,867 crwdns2915208:0crwdne2915208:0
crwdns2944067:019crwdne2944067:0
Why not show the great display? =\
Diego Sampaio - crwdns2934203:0crwdne2934203:0
Do you see the NFC module ? (the phone come frome England?)
Beacause there is a big disscution between ethier the NFC is not implemented on phone, maybe the chip is on ?
Forever TPC - crwdns2934203:0crwdne2934203:0
no, it should be from germany, I bought it there ;)
lon -
I'll change it for you ;)
lon -
Where can I purchase any mobile NFC chip and solder on to Galaxy S2 International version (I9100)?
Tai Li -
Which is the NFC chip in this?
Pradeep - crwdns2934203:0crwdne2934203:0
I'm watching you guys... i'm waiting to take back my s2 from service..
water damage... they told me that it will be fixed with 380 euro.....
ofcourse i will not pay the money so i'll try to fix it my shelf,,
the phone doesn't turn on at all and they told me that there is oxidation to the main card and to the screen..
i dont understand their report so i'm waiting to take it in my hands..
greek service for ever!!!!
kostas kotsoris - crwdns2934203:0crwdne2934203:0
have a question. the display cracked till the point that you cant use the or see the screen. Sprint sent me a replacement since I have insurance., but I need information off the internal usb. Is there a way to unplug of one phone and plug to another and get the information off
Orlando Lockett - crwdns2934203:0crwdne2934203:0
hi, i´ve a sgs2, but now i can´t connect wifi, i mean i can´t turn on the wifi because it´s turn off after 10 seconds... so i´d like to know if the chip wifi can be changed o i´ve tu o buy a new phone, thanks¡¡¡¡¡¡¡¡¡¡¡¡
ANGEL - crwdns2934203:0crwdne2934203:0
i was just wondering,
the volume key
how do you solder it on if you ripped it off when you took your phone apart?
and, is it soldered on...?
Ali Wannous - crwdns2934203:0crwdne2934203:0
new keys are easy to find online, and you'll need to use a fine tip soldering iron to put the new one on
LE55ONS -
Hi.. My son threw my samaxy galaxy 2 in a tea the fone was workin fine but now says no signal now with a circle and line through that circle in it... Can anyone help to tell me where the service bit is so .I can clean or any other ideas please
Thank you Sarah
Sarah Jane baker - crwdns2934203:0crwdne2934203:0
i have samsung galaxy s2 and its boot is damage,
not be booted since when it suddenly restart and stuck on samsung logo
and after that i have done restore factory setting by booting my smartphone
but restore factory setting failed and again i booted my phone and done wipe cache after that
my phone stuck on android logo then i shut it down by pulling the battery out
and from that my phone are not starting and it is like a dead phone.
plz tell me solution, it will be fine or not.
hamad - crwdns2934203:0crwdne2934203:0
cannot charge thru usb charging port. have to turn off, remove battery and charge on external charger. i do this 3-4/day 1hour ea time. can the usb charging port be fixed?
lindadeplitch - crwdns2934203:0crwdne2934203:0
hi my ribbon cable (motherboard) is ripped how can i get that repaired, any idea's as i have valuable data on that phone..
Shaan Awaz - crwdns2934203:0crwdne2934203:0
How do i fix wifi. My wifi won't turn on i have a samsung galaxy light 2. Can you email at kblackall69@gmail.com thank you
kalenawebster - crwdns2934203:0crwdne2934203:0
WIFi is not connecting. Which unit oe module need to be replaced. Please email to anead2008@gmail.com
Uncle Dan - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 562,890
