Today we turn our tools on a rather inconspicuous phone—one of the newest members in Samsung’s mid-tier Galaxy J series, the J6. It debuted alongside the J4 and J8, so what makes it special? Well for one thing, it’s getting the teardown treatment.
Its predecessors, the J3 and J5, seem to be particularly popular amongst our Latin American and Spanish-speaking fixer friends. Since they asked with a polite por favor, we are only too happy to answer. Let’s give them what they want, and peek inside the J6.
To keep up-to-date on all of our teardown exploits, follow us on Instagram, Twitter, and Facebook.
With annual updates for the J3, J5 and J7 phones, the J6 has its debut this year.
A short spec check shows:
5.6" Super AMOLED display with a resolution of 720 × 1480
Octa-core, 1.6 GHz Cortex-A53 Exynos 7870 processor, paired with 3 GB of RAM
Built-in 32 GB storage (with an additional 256 GB available via microSD card expansion)
13 MP primary rear-facing camera, plus an 8 MP selfie cam
149.3 × 70.2 × 8.2 mm in size, and 154 g on the scale
Android 8.0
While scanning the outside for screws, we note the good ol' Micro-USB port. And a headphone jack next to it.
Our teardown specimen of the J6 is the Duos version, with an additional SIM and SD card slot on the side.
crwdns2935267:0crwdne2935267:0iSclack$24.99
With no exterior screws to guide the way, we attack the back cover as a possible point of entry—but after some unsuccessful heating and prying, we give up and try our luck on the display.
After some iOpener and iSclack action, the touch panel seems to separate pretty cleanly. Is this a repairable, non-bonded display like back in the old days?
Sadly, no—it seems we were foiled by some extra-strong adhesive under the sAMOLED panel, which held fast while the touch panel glue gave way. End result: busted display.
We unplug the protected connector and remove the newly unfused display assembly to continue our journey.
If you're ever working on this phone, please I beg you just don't bother or tell your customer not to if it's a minor issue like power button not clicking well because it's like this is guaranteed to happen, it's a repairability nightmare
Where I &&^&@@ up was not checking iFixit before proceeding now I have to buy a new screen for someone I was just trying to help for free :(
crwdns2935267:0crwdne2935267:0Mako Driver Kit - 64 Precision Bits$39.95
It seems those screws we hoped to see on the outside were already used up on the midframe.
So we bring out our Mako Driver Kit to remove a bunch of Phillips screws …
… and finally pop out the midframe.
On the other side of the midframe, we finally find the battery—glued in place.
After a little heat and some gentle convincing, we can push out the power pack for inspection.
Coming in at 11.55 Wh (3,000 mAh at 3.85 V), this is on par with last year's J5—and a bit weaker than the 2017 J7 Pro (3,600 mAh).
Before we take a look at the motherboard, we remove the 8 MP front-facing camera at the top, and the 3.5 mm headphone jack at the bottom.
Much to our dismay, the USB charging port is soldered onto the motherboard—nothing to take out (or easily repair) here.
Without further ado, we take out the motherboard …
… and remove the 13 MP rear camera, with its ƒ/1.9 aperture.
On the front of the motherboard, we find:
Samsung KLMBG2JETD-B041 32 GB NAND Flash Memory
Samsung K4EHE304EC-AGCF ? 3 GB Memory layered over the Exynos 7870 chip
And on the back, we have:
Samsung Shannon 515 power management IC
Samsung Shannon 925 RF Tranceiver
Skyworks Multiband Power Amplifier SKY77656-11
This completes our abbreviated teardown, with all components lined up for inspection. We'd hoped for a bit more modularity in this mid-range phone—but let's tally up the points and see how the J6 performed.
- The only screws used are standard Phillips screws (granted, there are almost too many).
- Display repair is prioritized, since it is the first part out—but at the cost of probably damaging it, making repairs to other components risky.
- The battery is buried beneath the motherboard and adhered to the midframe, hindering its replacement.
- The high-wear USB port is soldered to the motherboard, requiring a high level of skills and equipment for this all-too-common repair.
crwdns2935195:0crwdne2935195:0
crwdns2935097:0crwdne2935097:0
crwdns2935199:0crwdne2935199:0
crwdns2944067:012crwdne2944067:0
Where is the Simms card reader?
Cara, que aparelho complicado. Apliquei todos os métodos que conheço e a tela quebrou da mesma maneira que com vcs… Muito ruim! naõvou receber estes nem para troca de bateria… Alto risco de prejuízo…
Design feito para não facilitar manutenção. Se mantivessem o acesso dos parafusos pela parte traseira se conseguiria soltar a estrutura intermediária com o display ainda acoplado e depois, retirada a bateria, se removeria a cola sem destruir tudo… Design medíocre.. Ou bem planejado para ser descartável.
J6 não quer ligar
Aqui em nossa assistência, esquentamos a tela na maquina um pouco e após feito isso, começamos o trabalho da retirada do display, com a ajuda de sucção descolamos uma pequena fresta, e introduzimos pouco a pouco álcool 99,8% , e com a ajuda de uma espátula, para que possamos retirar o display sem maiores transtornos…paciência é de grande importância para abrir esse tipo de aparelho. Fazemos isso com todos os dispositivos que precisa retirar o display, e que seja amoled ( super amoled, oled, etc ) devido não correr o risco de manchar com o álcool, como acontece nos aparelhos com display LCD que mancha com o álcool que acaba penetrando nas camadas do lcd.
[quote]O meu tomou “banho" de água salgada… comprei o aparelho tem 3 meses… e aí meu povo? Será q tem jeito ?
possivelmente sim amigo,tem que dar um banho ultrassônico para remover todo tipo de impurezas em sua placa ,talvez assim consiga ressuscitar seu aparelho.
oficinas de celulares fazem esse trabalho
Please help me where i can find charging ic.
very helpful. thank you
Boa noite, alguém sabe que sensor é o que está a cima da bateria na fotografia do passo 9? Essa peça vem colado na tampa traseira. Sabem me dizer se o telemóvel deixa de carregar danificando esse sensor? A tirar a tampa traseira parti o filamento desse sensor e agora não carrega.
Obrigado
One of my phone's SIM CARD place is not working, please solve it i want to use two SIM cards. My phone is samsung galaxy J6. Thanks,
Meu j6 esta com o botão power enterrado.
