crwdns2936621:0crwdne2936621:0
crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Samsung Galaxy Buds Pluscrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
    crwdns2935195:0crwdne2935195:0
    • External assemblies are held together with clips instead of glue, making for a non-destructive entry process.
    • Disassembly can be accomplished with common prying tools and a Phillips screwdriver.
    • The earbuds use rechargeable coin-cell batteries that are easier than ever to replace.
    • Opening procedure is a bit unorthodox, and can cause cosmetic damage to the buds.
    • Careful prying is required throughout to separate components without tearing fragile cables or otherwise damaging the buds.
    crwdns2935097:0crwdne2935097:0
    7
    crwdns2935197:07crwdne2935197:0
    crwdns2935199:0crwdne2935199:0
Taylor Dixon
crwdns2935283:006/26/18crwdne2935283:0
69,932 crwdns2915208:0crwdne2915208:0
crwdns2935297:094crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Would be nice if you could ID the rest of the major IC’s too.
Sean Davis - crwdns2934203:0crwdne2934203:0
where can I find replacement parts?
Michel - crwdns2934203:0crwdne2934203:0
More wireless earbud teardowns, please! I would also like to see the Galaxy Buds+ drivers.
Mike Housholder - crwdns2934203:0crwdne2934203:0
possible to swap in a higher capacity battery for the buds+ and the case to increase total usable time in between charging.
K T - crwdns2934203:0crwdne2934203:0
is there space to possibly double the capacity of buds case by soldering another 1.03wh battery in parallel?
How do I calibrate the battery for the buds+ case if I replaced the battery for it. If so, how long do I calibrate it for? I previously replaced the batteries for the earbuds themselves and was informed to calibrate it until fully charged plus 2 hours, then let it drain completely, then recharge it to full. Does this sound right or am I off for the battery case?
Craig Bowser - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 148
crwdns2942667:0crwdne2942667:0 22,414
