crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Samsung Galaxy A14 5Gcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Samsung Galaxy A14 5G Teardown, Remove Sim Tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove Sim Card & SD Card Tray with a Sim Ejector Tool
  2. Samsung Galaxy A14 5G Teardown, Pop Out Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A14 5G Teardown, Pop Out Back Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A14 5G Teardown, Pop Out Back Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop out the back cover using a spudger or opening pick
  3. Samsung Galaxy A14 5G Teardown, Removing Fingerprint Scanner (Optional): crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After "popping out" the back cover, you can remove the Scanner from the back cover or set the back cover aside, insert a thin pick in from the screen side and gently work round undoing the clips. When you lift the back off be mindful of the power switch/fingerprint reader cable. Lift the back away slowly.
  4. Samsung Galaxy A14 5G Teardown, Unscrew All 16 Screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A14 5G Teardown, Unscrew All 16 Screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A14 5G Teardown, Unscrew All 16 Screws: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all 16 screws on the plates
  5. Samsung Galaxy A14 5G Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A14 5G Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop off the 2 plates holding on the Motherboard and Charging Port
  6. Samsung Galaxy A14 5G Teardown, Unplug Cables: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A14 5G Teardown, Unplug Cables: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A14 5G Teardown, Unplug Cables: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the battery, display cables, and fingerprint scanner from the Phone
  7. Samsung Galaxy A14 5G Teardown, Unplug Front Camera & Antenna Cables: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A14 5G Teardown, Unplug Front Camera & Antenna Cables: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A14 5G Teardown, Unplug Front Camera & Antenna Cables: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the front camera & Antenna Cables from the phone
  8. Samsung Galaxy A14 5G Teardown, Unplug Charging Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the Charging Port from the Display Cable and Antenna Cables
  9. Samsung Galaxy A14 5G Teardown, Remove Charging Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry Up on the Charging Port
  10. Samsung Galaxy A14 5G Teardown, Remove Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry Up on the Motherboard
  11. Samsung Galaxy A14 5G Teardown, Reassemble Phone: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A14 5G Teardown, Reassemble Phone: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do what you just did but in reverse
FadingBulb57227
crwdns2935283:002/01/24crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
What is the black square the connects the speaker.
Judy LeBrun - crwdns2934203:0crwdne2934203:0
it is a foam pad
FadingBulb57227 -
No mention of the battery.... assuming it must be removed also...
Heather Gussman - crwdns2934203:0crwdne2934203:0
Peel part A then Pull up on B, if it is too hard to pull then add isopropyl alcohol
FadingBulb57227 -
crwdns2936753:07crwdne2936753:0 62
crwdns2936753:030crwdne2936753:0 300
crwdns2942667:0crwdne2942667:0 7,894
