SYNOLOGY DS718+ Teardown
  1. SYNOLOGY DS718+ Teardown, Case presentation:  front panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This NAS DS718 + is equipped with 4 GB of RAM (6 GB max.), an INTEL Celeron J3455 64-bit Quad processor, two bays for SATA drives (HDD, or SSD).
    • FRONT PANEL : you can notice on the right side, disks LEDs disapeared. You can find them now just on the top of the disk bays.
    • status LEDs
    • power buton (startup / shutdown)
    • 1 x USB 3 port
    • "copy" buton
    • 2 x disk support (caddy / cage)
    • disk bay lock
  2. SYNOLOGY DS718+ Teardown, Cas presentation: rear panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • REAR PANEL
    • 1 x 92mm fan
    • 2 x EHTERNET RJ45 Gigabit port
    • 2 x USB 3 port
    • 1 x eSATA port
    • 1 x power connector
    • 1 x Kensington security incision (K-lock)
    • RESET buton
  3. SYNOLOGY DS718+ Teardown, Backplane and memory access: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Backplane and memory access: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Backplane and memory access: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before teardown, unlock the disk media with the key.
    • It's a new appreciable feature, the memory slots are now directly reachable.
    • first memory slot
    • seonc memory slot (not populated)
    • The previous revision (DS716+ II) allowed this operation but a piece of metal prevent to remove memory.
  4. SYNOLOGY DS718+ Teardown, Teardown: Rear Panel - Step 1 / 3: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: Rear Panel - Step 1 / 3: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: Rear Panel - Step 1 / 3: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1 - Remove the two screws placed under the NAS, on rear side.
    • 2 - Remove the screw placed in the middle of the rear panel.
  5. SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 2 / 3: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 2 / 3: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 2 / 3: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the rear panel …
    • slightly pull the lower part of the rear panel so that the lugs do not touch the case, then ...
    • drag the facade upwards …
    • The back cover is held by two notches into the case.
  6. SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 3 / 3: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 3 / 3: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 3 / 3: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once removed, remove the fan connector from the motherboard.
  7. SYNOLOGY DS718+ Teardown, Removing the Metal Housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Removing the Metal Housing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Removing the Metal Housing: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the rear panel is removed, the housing can be removed. To do so drag the cover about 1 cm to the back of the NAS then lift the hood upwards.
  8. SYNOLOGY DS718+ Teardown, Naked case before disassembling metal housing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Naked case before disassembling metal housing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Naked case before disassembling metal housing: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now remains the front to remove ...
    • Here are some photographs of the case and the internal structure + screws.
  9. SYNOLOGY DS718+ Teardown, Teradown: front panel - step 1 / 2: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teradown: front panel - step 1 / 2: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teradown: front panel - step 1 / 2: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two screws under the box on the front side and then ...
    • in the same way as for the rear panel, lift the hood slightly ...
  10. SYNOLOGY DS718+ Teardown, Teardown: front panel - step 2 / 2: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: front panel - step 2 / 2: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • and remove the front panel …
  11. SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 1/3: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 1/3: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 1/3: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • x 4 screws to remove …
    • x 2 on the right side panel
    • and x 2 on the upper part
  12. SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 2/3: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 2/3: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 2/3: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This part is delicate to assembly as to disassembly. Read full instructions carefully before handling.
    • The guidance remains relatively accurate but the connector for the LED card drives is fragile. Do not force when removing or inserting the side flange.
    • electronic card LED disks
    • riser for SATA backplane (electronic card or daughter card)
    • electronic card riser (USB and e-SATA)
  13. SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 3/3: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 3/3: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 3/3: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • INSTRUCTIONS :
    • use both hands ...
    • pull gradually ...
    • everything must come without forcing!
    • Pay attention also to the metallic tape ... take it off if possible!
  14. SYNOLOGY DS718+ Teardown, Teardown: motherboard and memory: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SYNOLOGY DS718+ Teardown, Teardown: motherboard and memory: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • motherboard (processor side)
    • memory card
    • last pictures are bad …
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Sébastien
crwdns2935283:012/14/15crwdne2935283:0
4,498 crwdns2915208:0crwdne2915208:0
AEM (ANIMA EX MACHINA) crwdns2935289:0AEM (ANIMA EX MACHINA)crwdne2935289:0
Business
1 hour? I did it in 20 minutes that's teardown and reassembly!!?!
Ken Richner - crwdns2934203:0crwdne2934203:0
PLZ read the introduction more carefully !
Sébastien -
How to replace a larger heat pipe radiator??
love3kkk - crwdns2934203:0crwdne2934203:0
Any suggestions on Mother board update for the DS218+ & DS718+ ?
WA FOR SALE - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 116
crwdns2942667:0crwdne2942667:0 9,806
