crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0S-993A Desolder Guncrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. S-993A Desolder Gun Teardown, S-993A Desolder Gun Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 S-993A Desolder Gun Teardown, S-993A Desolder Gun Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Desoldering Pump
    $3.99
    • This is a partial teardown of the S-993A desolder gun, which is cheaply available from China.
    • It is not intended to be a full teardown, but it should be enough to indicate where all components go, and where all connections are. This should be enough for someone to fix this device.
  2. S-993A Desolder Gun Teardown, Remove three 18mm screws from body: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are three 18mm screws, locations are marked in the picture.
  3. S-993A Desolder Gun Teardown, Remove three 14mm screws from body: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are three 14mm screws, locations are marked in the picture.
  4. S-993A Desolder Gun Teardown, Remove one 7mm screw from body: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is one 7mm screws, location is marked in the picture.
  5. S-993A Desolder Gun Teardown, Open the body: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the body can be opened. The pump tends to stick a little to the body, apply gentle pressure to keep it in place.
    • The earth wire is connected to the nozzle. The connection is marked in the picture.
  6. S-993A Desolder Gun Teardown, Remove the screws for the circuit board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws for the strain relief.
    • Remove the two tiny screws that hold the circuit board in place. Use a PH2 screwdriver for this so you don't molest the screws.
  7. S-993A Desolder Gun Teardown, Remove the circuit board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 S-993A Desolder Gun Teardown, Remove the circuit board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull back the circuit board in a straight manner. It's still kept in place by the temperature adjustment wheel in the handle. When pulled back straight, the wheel will pop out.
Jurrie
crwdns2935283:005/07/21crwdne2935283:0
667 crwdns2915208:0crwdne2915208:0
Thanks for the quick teardown… just wanted to let people know that if yours stops having suction, you need to take apart the diaphragm part and clean it out. As long as the motor turns, it should still be pulling air.
Mine got clogged with flux or something and stopped suction. Just be sure to note which opening the little snorkel connects to when taking apart the diaphragm.
A little rubbing alcohol and small toothpicks/lint-free sticks/ pipe cleaners should help clean any clogs or remove flux that might stick up the works. I thought as long as there were the little fabric filters, nothing would get through, but I was wrong as flux, or some gunk did get through. Once you clean it, work the rubber duct up and down to make sure you hear air moving. Good luck.
a f - crwdns2934203:0crwdne2934203:0
I replaced a faulty circuit board in one of these, and I am having some problems adjusting the temperature afterwards. Initially with the replacement circuit board the temperatures were WAY too high. I found some potentiometers to adjust, but I am not really sure how they operate. I might think one of them controls the minimum temperature and the other wound works like a k-factor for the temperature range.
If anyone has any knowledge to depart regarding this I would be eternally grateful.
mrsazz - crwdns2934203:0crwdne2934203:0
I believe the two blue pots next to each other control your heating element,one is a high limit and one is a low limit temperature adjustment very small movements should be made when checking the actual temperature change,to do so you will need a soldering iron thermometer readily available on Amazon or ebay for around $15 they will get you in the ballpark.
Rick Martin - crwdns2934203:0crwdne2934203:0
I need to replace the motor in mine but I'm not sure on the specs. What voltage, rpm, etc, should I look for? Thank you.
D Holmes - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,145
