This is just a general teardown guide for the robotic vacuum cleaner Roborock S5 Max.
Remove the front half. It is only held on by latches.
Remove the screws and plastic tabs holding the back half in place.
Remove the back half.
Remove the rubber caps.
Remove the screws of the LiDAR cage, then the cage itself.
Remove the screws of the LiDAR, then the LiDAR itself.
Remove the side brush.
Remove the screws.
Lift the bottom cover off.
Unscrew the screws.
Remove the lid of the bumper, then the bumper itself.
Grab it by the tab, then lift it out, tilting it towards the cable.
Once you can reach it, squeeze the connector to release it.
Remove the screws from the side brush motor.
Simply lift it out.
Remove the rest of the screws from the chassis.
Remove the final 4 screws (these are non-magnetic).
Flip it over, then pull the chassis apart.
