This is just a general teardown guide for the robotic vacuum cleaner Roborock Q5 Pro.
Flip it on its head, then remove the dustbin.
Remove the side brush using a PH2 screwdriver.
Remove the screws using a PH2 screwdriver.
Then, pull the bottom cover off.
Lift it up on the left.
Detach the connector by squeezing the release tab, then pull it out.
Remove the marked screws using a PH1 screwdriver.
Then simply lift the lid off.
Flip the robot over.
Tilt the bumper forwards and move it upwards to remove it.
Flip it back over.
Simply lift it out.
Remove the marked screws using a PH2 screwdriver.
Use a prying tool to get these apart before taking it apart.
Flip it over and simply pull the chassis halves apart.
For keeping the screws organized, I use a 24 cup tray that originally held 24 small cupcakes from the bakery section of the Grocery store. I took a Sharpie and numbered the bottom of the cups from 1 to 24. When I take something apart, I write a note as to what was done and what cup the screws went into.
