RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown
    • Face lens down, (front on table)
    • Remove 3 screws on the lens mount
    • Remove lens mount
    • Pull / push trpod mount towards back of the lens, and remove it. Be patient, it is very precisely assembled.
    • Loosen tripod ring, till it can rotate.
    • Remove tripod ring. Be aware, the is a 90 degree stepping steel ball inside.
    • photos TBD
  1. RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do NOT remove 3 focus scale calibration screws. I actually did that when attempting disassembly. And luckily, I also marked the original position before that.
    • I tried to remove the front element group first. But the thread is some how locked and impossible to turn using my current tooling. So I gave up, and most cleaning does not need to remove front group.
    • Remove focus ring rubber. Take your time, it's a huge piece and might be glued.
    I perform the teardown in order to clear and regrease the helicoid. It's ok now, but ... the Infinity port moved by 3 inc. Should I remove the 3 focus scale calibration screws and rotate the focus flange?
    Sandro Marchetti - crwdns2934203:0crwdne2934203:0
  2. RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 2 focus stop screws. Your's might be in different holes. Also you may like to calibrate that. There 3 holes at the infinity end, and 2 at the close-up (8m / 25 ft) end.
  3. RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown, Mark the point!: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown, Mark the point!: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • READ THIS FIRST! In the following step, rotate slowly, and apply gentle force pulling front and rear apart, and mark the position of separate.
    • Rotate the rear half of the lens, towards close-up direction (CW as looking downwards), pass 8m/25 feet mark and continue, while applying gentle force pulling rear part up, until they separate, mark the point.
    • When assemble them back, attach from this angle/point.
  4. RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The front tube, thread on the inner side.
    • The rear tube, thread on the outer side.
  5. RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RefIex-Nikkor 1000mm f11 Mirror lens (partial) Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is just a partial tear down. This lens is extremely well made, and very very precise.
    • Until this point, this is a reasonable "maintenance teardown". And you can do most mirror and lens cleaning and grease replace.
    • Putting them back from the point/angle you marked in previous step, the focus scale does not need a calibration.
Terrance
crwdns2935283:011/17/09crwdne2935283:0
6,368 crwdns2915208:0crwdne2915208:0
crwdns2935297:017crwdne2935297:0
I am looking for more understanding of this breakdown. I have questions about the fragility of the components and how to clean the interior of the front glass of mold spores. Additionally i would love to understand how to calibrate its focus. Can you advise?
zack - crwdns2934203:0crwdne2934203:0
This is a professional lens, built very tough. Primary mirror cleaning is quite easy. but front element is kind of tricky. because there’s an inner thread there covered by damping oil/grease. Maybe you should try remove it from the front. remove the filter/cap thread ring first(My cap used to stuck with this ring so I‘ve got this far)…
In step 3, there are 2+3 screw holes at each end , those are for focus ring stopping screws. 3 for inf end and 2 for close end (if my memory is correct). But this is for adjustment instead of “calibration“. By my guess a giant lens like this could never be calibrated due to the TCE of aluminium tube. that’s why the focus ring is allow to go beyond inf.
Terrance -
crwdns2942667:0crwdne2942667:0 1,866
